[PATCH] clock:_TOD_To_seconds(): Fix year 2514 overflow
Tue Apr 13 16:03:21 UTC 2021
Hello,
On 08/04/2021 15:41, Frank Kuehndel wrote:
> + *  @brief Latest year to which a time of day can be initialized.
> + *  The following constant defines the latest year to which an
> + *  RTEMS time of day can be set using rtems_clock_set().
> + *  32 bits can accept as latest point in time 2106-Feb-7 6:28:15
> + *  but to simplify the implementation, is was decided to only
> + *  check that the year is not greater than the year of this constant.
> + *  The internal realtime clock can run centuries longer but in
> + *  contrast to the POSIX API, the RTEMS Classic API does not
> + *  support this for efficiency reasons.
> +#define TOD_LATEST_YEAR 2105
any objections to use this approach? If we want to support years after
2105 in the Classic API, then we would need 64-bit values and
calculations in several places. I think an RTEMS system which operates
after 2105 is currently a bit unrealistic.
If we limit the time frame to the year 2100 we could simplify
_TOD_Validate() a bit more since all years % 4 == 0 are leap years in
the range 1988 to 2100 (exclusive).
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
