[PATCH] clock:_TOD_To_seconds(): Fix year 2514 overflow
Sebastian Huber
Mon Apr 19 15:44:01 UTC 2021
On 13/04/2021 18:03, Sebastian Huber wrote:
> Hello,
> On 08/04/2021 15:41, Frank Kuehndel wrote:
>> + * @brief Latest year to which a time of day can be initialized.
>> + * The following constant defines the latest year to which an
>> + * RTEMS time of day can be set using rtems_clock_set().
>> + * 32 bits can accept as latest point in time 2106-Feb-7 6:28:15
>> + * but to simplify the implementation, is was decided to only
>> + * check that the year is not greater than the year of this constant.
>> + * The internal realtime clock can run centuries longer but in
>> + * contrast to the POSIX API, the RTEMS Classic API does not
>> + * support this for efficiency reasons.
>> +#define TOD_LATEST_YEAR 2105
> any objections to use this approach? If we want to support years after
> 2105 in the Classic API, then we would need 64-bit values and
> calculations in several places. I think an RTEMS system which operates
> after 2105 is currently a bit unrealistic.
> If we limit the time frame to the year 2100 we could simplify
> _TOD_Validate() a bit more since all years % 4 == 0 are leap years in
> the range 1988 to 2100 (exclusive).
If there are no objections, then I will check this in on Wednesday and
send a documentation update.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
