[PATCH rtems-libbsd 1/2] MMCSD: Use cache aligned alloc for ioctl
Christian Mauderer
christian.mauderer at embedded-brains.de
Wed Apr 14 07:20:44 UTC 2021
Some drivers can't easily work with buffers that are not cache aligned
and have an arbitrary length. Therefore use an aligned malloc instead.
freebsd/sys/dev/mmc/mmcsd.c | 4 ++++
1 file changed, 4 insertions(+)
diff --git a/freebsd/sys/dev/mmc/mmcsd.c b/freebsd/sys/dev/mmc/mmcsd.c
index 21f54046..bd45b419 100644
--- a/freebsd/sys/dev/mmc/mmcsd.c
+++ b/freebsd/sys/dev/mmc/mmcsd.c
@@ -1196,7 +1196,11 @@ mmcsd_ioctl_cmd(struct mmcsd_part *part, struct mmc_ioc_cmd *mic, int fflag)
goto out;
if (len != 0) {
+#ifndef __rtems__
dp = malloc(len, M_TEMP, M_WAITOK);
+#else /* __rtems__ */
+ dp = rtems_cache_aligned_malloc(len);
+#endif /* __rtems__ */
err = copyin((void *)(uintptr_t)mic->data_ptr, dp, len);
if (err != 0)
goto out;
2.26.2
