Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Apr 14 13:32:10 UTC 2021
That's an error I haven't seen before. It seems like the BOOT.BIN/u-boot
you're using is relatively limited; where did it come from? Most
recently, I've pulled the BOOT.BIN from the PetaLinux prebuilts for my
particular dev boards.
Kinsey
On 4/14/2021 08:21, Richi Dubey wrote:
> Trying to boot directly from the .img file also fails:
> ZynqMP> tftpboot 0x3000000 rdubey/sp01.img
> Using ethernet at ff0e0000 device
> TFTP from server 172.19.0.3; our IP address is 172.19.2.40
> Filename 'rdubey/sp01.img'.
> Load address: 0x3000000
> Loading: ####
> 6.1 MiB/s
> done
> Bytes transferred = 50978 (c722 hex)
> ZynqMP> bootm 0x3000000 ; reset
> ## Booting kernel from Legacy Image at 03000000 ...
> Image Name: RTEMS
> Image Type: ARM Linux Kernel Image (gzip compressed)
> Data Size: 50914 Bytes = 49.7 KiB
> Load Address: 00300000
> Entry Point: 00300000
> Verifying Checksum ... OK
> Uncompressing Kernel Image ... OK
> FDT and ATAGS support not compiled in - hanging
> ### ERROR ### Please RESET the board ###
> What can I do now?
> On Wed, Apr 14, 2021 at 6:11 PM Kinsey Moore <kinsey.moore at oarcorp.com
> <mailto:kinsey.moore at oarcorp.com>> wrote:
> If you’re only running RTEMS, you should be able to drop the FDT
> commands since that what appears to be causing the problem and I
> don’t think that the arm/xilinx_zynqmp BSP uses it at all.
> Kinsey
> *From:* Richi Dubey <richidubey at gmail.com
> <mailto:richidubey at gmail.com>>
> *Sent:* Wednesday, April 14, 2021 01:01
> *To:* Kinsey Moore <kinsey.moore at oarcorp.com
> <mailto:kinsey.moore at oarcorp.com>>; rtems-devel at rtems.org
> <mailto:rtems-devel at rtems.org> <devel at rtems.org
> <mailto:devel at rtems.org>>
> *Subject:* Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
> Hi,
> I followed the 8.2.23 docs
> <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#xilinx-zynqmp> to
> build rtems for the xilinx_zynqmp_ultra96 bsp since it was the
> only bsp corresponding to xilinx-zynqmp in the rtems-bsp.
> Then I followed the boot via Uboot section 8.2.1.1 on docs
> <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#boot-via-u-boot>,
> but the uboot on zcu106 does not have a run loadfdt command, and
> its alternative is fdt addr [address]. But something is wrong, I
> cannot run the sp01.img file:
> With fdt:
> Loading: ####
> 6.9 MiB/s
> done
> ZynqMP> fdt addr 0x2A00000
> ZynqMP> bootm 0x3000000 - 0x2A00000 ; reset
> Image Name: RTEMS
> ## Flattened Device Tree blob at 02a00000
> Booting using the fdt blob at 0x2a00000
> Loading Device Tree to 0000000007ff1000, end 0000000007fff257
> ... OK
> fdt_find_or_add_subnode: chosen: FDT_ERR_BADSTRUCTURE
> ERROR: /chosen node create failed
> - must RESET the board to recover.
> FDT creation failed! hanging...### ERROR ### Please RESET the
> board ###
> With loading the system.dtb that I generally use for loading yocto
> linux images:
> ZynqMP> tftpboot 0x2A00000 rdubey/system.dtb
> TFTP from server 172.19.0.3; our IP address is 172.19.253.142
> Filename 'rdubey/system.dtb'.
> Load address: 0x2a00000
> Loading: ###T #
> 8.8 KiB/s
> done
> Bytes transferred = 45656 (b258 hex)
> Loading: ####
> 1.7 MiB/s
> done
> Image Name: RTEMS
> ... OK
> Starting kernel ...
> "Synchronous Abort" handler, esr 0x02000000
> elr: ffffffff90593000 lr : 0000000010081868 (reloc)
> elr: 0000000000300000 lr : 000000007fdee868
> x0 : 0000000000000000 x1 : 0000000000000000
> x2 : 0000000007ff1000 x3 : 0000000000000000
> x4 : 0000000000300000 x5 : 0000000000000000
> x6 : 0000000000000008 x7 : 0000000000000000
> x8 : 000000007dda0650 x9 : 0000000001008000
> x10: 000000000a200023 x11: 0000000000000002
> x12: 0000000000000002 x13: 00000000000096f4
> x14: 000000007dda06ac x15: 000000007fdee224
> x16: 0000000000000002 x17: 0000000007fff258
> x18: 000000007ddacde8 x19: 000000007fead720
> x20: 0000000000000000 x21: 0000000000000400
> x22: 000000000000071f x23: 000000007fdeedb8
> x24: 0000000000000003 x25: 000000007ddbd378
> x26: 000000007fe9ac18 x27: 0000000000300000
> x28: 0000000003000040 x29: 000000007dda0790
> Resetting CPU ...
> What might be going wrong? zcu106 is a multi processor board, so
> do I need to do something special to run the sp01 test? I have not
> tested any other .exe (or .img) so far.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210414/fb0d51b8/attachment-0001.html>
