Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Wed Apr 14 13:38:53 UTC 2021
Hi Richi,
In your log it says:
Image Type:   ARM Linux Kernel Image (gzip compressed)
At least for our zedboard devices we use the following main options for mkimage.
mkimage  -A arm -O rtems -T kernel
Which yields  for me:
Image Type:   ARM RTEMS Kernel Image (gzip compressed)
IIRC the difference between -O rtems  and -O linux is subtle, but maybe that helps.
Best regards,
    Jan
From: devel <devel-bounces at rtems.org> On Behalf Of Richi Dubey
Sent: Wednesday, April 14, 2021 3:22 PM
To: Kinsey Moore <kinsey.moore at oarcorp.com>
Cc: rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
Trying to boot directly from the .img  file also fails:
ZynqMP> tftpboot 0x3000000 rdubey/sp01.img
Using ethernet at ff0e0000 device
TFTP from server 172.19.0.3; our IP address is 172.19.2.40
Filename 'rdubey/sp01.img'.
Load address: 0x3000000
Loading: ####
         6.1 MiB/s
done
Bytes transferred = 50978 (c722 hex)
ZynqMP> bootm  0x3000000  ; reset
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   RTEMS
   Data Size:    50914 Bytes = 49.7 KiB
   Load Address: 00300000
   Entry Point:  00300000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
What can I do now?
On Wed, Apr 14, 2021 at 6:11 PM Kinsey Moore <kinsey.moore at oarcorp.com<mailto:kinsey.moore at oarcorp.com>> wrote:
If you’re only running RTEMS, you should be able to drop the FDT commands since that what appears to be causing the problem and I don’t think that the arm/xilinx_zynqmp BSP uses it at all.
Kinsey
From: Richi Dubey <richidubey at gmail.com<mailto:richidubey at gmail.com>>
Sent: Wednesday, April 14, 2021 01:01
To: Kinsey Moore <kinsey.moore at oarcorp.com<mailto:kinsey.moore at oarcorp.com>>; rtems-devel at rtems.org<mailto:rtems-devel at rtems.org> <devel at rtems.org<mailto:devel at rtems.org>>
Subject: Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
Hi,
I followed the 8.2.23 docs<https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#xilinx-zynqmp> to build rtems for the xilinx_zynqmp_ultra96 bsp since it was the only bsp corresponding to xilinx-zynqmp in the rtems-bsp.
Then I followed the boot via Uboot section 8.2.1.1 on docs<https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#boot-via-u-boot>, but the uboot on zcu106 does not have a run loadfdt command, and its alternative is fdt addr [address]. But something is wrong, I cannot run the sp01.img file:
With fdt:
Loading: ####
         6.9 MiB/s
done
ZynqMP> fdt addr 0x2A00000
ZynqMP> bootm  0x3000000 - 0x2A00000 ; reset
   Image Name:   RTEMS
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x2a00000
   Loading Device Tree to 0000000007ff1000, end 0000000007fff257 ... OK
fdt_find_or_add_subnode: chosen: FDT_ERR_BADSTRUCTURE
ERROR: /chosen node create failed
 - must RESET the board to recover.
FDT creation failed! hanging...### ERROR ### Please RESET the board ###
With loading the system.dtb that I generally use for loading yocto linux images:
ZynqMP> tftpboot 0x2A00000 rdubey/system.dtb
TFTP from server 172.19.0.3; our IP address is 172.19.253.142
Filename 'rdubey/system.dtb'.
Load address: 0x2a00000
Loading: ###T #
         8.8 KiB/s
done
Bytes transferred = 45656 (b258 hex)
Loading: ####
         1.7 MiB/s
done
   Image Name:   RTEMS
Starting kernel ...
"Synchronous Abort" handler, esr 0x02000000
elr: ffffffff90593000 lr : 0000000010081868 (reloc)
elr: 0000000000300000 lr : 000000007fdee868
x0 : 0000000000000000 x1 : 0000000000000000
x2 : 0000000007ff1000 x3 : 0000000000000000
x4 : 0000000000300000 x5 : 0000000000000000
x6 : 0000000000000008 x7 : 0000000000000000
x8 : 000000007dda0650 x9 : 0000000001008000
x10: 000000000a200023 x11: 0000000000000002
x12: 0000000000000002 x13: 00000000000096f4
x14: 000000007dda06ac x15: 000000007fdee224
x16: 0000000000000002 x17: 0000000007fff258
x18: 000000007ddacde8 x19: 000000007fead720
x20: 0000000000000000 x21: 0000000000000400
x22: 000000000000071f x23: 000000007fdeedb8
x24: 0000000000000003 x25: 000000007ddbd378
x26: 000000007fe9ac18 x27: 0000000000300000
x28: 0000000003000040 x29: 000000007dda0790
Resetting CPU ...
What might be going wrong? zcu106 is a multi processor board, so do I need to do something special to run the sp01 test? I have not tested any other .exe (or .img) so far.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210414/279144f2/attachment-0001.html>
