[PATCH 2/2] main_rtrace.c: Fix Dereference after null check (CID #1399709)
Gedare Bloom
gedare at rtems.org
Wed Apr 14 16:25:45 UTC 2021
looks good.
On Wed, Apr 14, 2021 at 9:33 AM Joel Sherrill <joel at rtems.org> wrote:
> I'll pick on you. :)
> Please don't use the "title" that says "Fix ABC". There has to be a better description.
> Hopefully someone will ack the technical. I think it is right.
> --joel
> On Wed, Apr 14, 2021 at 9:20 AM Ryan Long <ryan.long at oarcorp.com> wrote:
>> ping
>> -----Original Message-----
>> From: Ryan Long <ryan.long at oarcorp.com>
>> Sent: Friday, March 12, 2021 8:56 AM
>> To: devel at rtems.org
>> Cc: Ryan Long <ryan.long at oarcorp.com>
>> Subject: [PATCH 2/2] main_rtrace.c: Fix Dereference after null check (CID #1399709)
>> CID 1399709: Dereference after null check in rtems_trace_buffering_shell_save().
>> Closes #4329
>> cpukit/libmisc/shell/main_rtrace.c | 1 +
>> 1 file changed, 1 insertion(+)
>> diff --git a/cpukit/libmisc/shell/main_rtrace.c b/cpukit/libmisc/shell/main_rtrace.c
>> index 753ab9d..e4f59c4 100644
>> --- a/cpukit/libmisc/shell/main_rtrace.c
>> +++ b/cpukit/libmisc/shell/main_rtrace.c
>> @@ -473,6 +473,7 @@ rtems_trace_buffering_shell_save (int argc, char *argv[])
>> close (out);
>> printf ("error: no memory\n");
>> + return 1;
>> memset (buf, 0, SAVE_BUF_SIZE);
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
