Booting a rtems exe on Zynq UltraScale+ MPSoC ZCU106 board
Kinsey Moore
kinsey.moore at oarcorp.com
Wed Apr 14 18:31:04 UTC 2021
That exception dump doesn't say a lot other than the ELR pointing at the
very first instruction in your image, so I suspect that u-boot is trying
to start your image as AArch64 code instead of AArch32/ARMv7 code. The
ESR just specifies that it was a 32-bit instruction that blew up (both
AArch32 and AArch64 use 32-bit instructions) instead of a 16-bit
instruction.
The u-boot images that come with the PetaLinux distributions default to
starting code as AArch64 at EL2, so you either need to figure out how to
make u-boot default to AArch32/ARMv7 at EL1 or build a new u-boot that
can do what you need and then package it into BOOT.bin using bootgen
(the code is available on github). From what I remember, the ARMv7 BSP
for ZynqMP mentions booting over JTAG.
Kinsey
On 4/14/2021 13:18, Richi Dubey wrote:
> Hi Jan, Kinsey,
> Thanks for your quick responses.
> I rebuilt the .img file with -O rtems option, and I think it is the
> standard uboot available from PetaLinux. It still fails, but I think
> it is related to RTEMS now:
> Welcome to minicom 2.7.1
> OPTIONS: I18n
> Compiled on May 6 2018, 08:02:47.Welcome to minicom 2.7.1
> OPTIONS: I18n
> Port /dev/ttyUSB32, 18:14:14
> Press CTRL-K Z for help on special keys
> Xilinx Zynq MP First Stage Boot Loader
> Release 2020.1 Jan 1 2021 - 07:33:16
> NOTICE: ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
> NOTICE: BL31: Secure code at 0x60000000
> NOTICE: BL31: Non secure code at 0x10080000
> NOTICE: BL31: v2.0(release):xilinx-v2019.1-12-g713dace9
> NOTICE: BL31: Built : 08:36:10, Sep 1 2020
> PMUFW: v1.1
> U-Boot 2019.01 (Sep 01 2020 - 08:36:54 +0000)
> Model: ZynqMP ZCU106 RevA
> Board: Xilinx ZynqMP
> DRAM: 4 GiB
> EL Level: EL2
> Chip ID: zu7ev
> MMC: mmc at ff170000: 0
> Loading Environment from SPI Flash... SF: Detected n25q512a with page
> size 512 B
> ytes, erase size 128 KiB, total 128 MiB
> OK
> In: serial at ff000000
> Out: serial at ff000000
> Err: serial at ff000000
> Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
> Warning: ethernet at ff0e0000 MAC addresses don't match:
> Address in ROM is 00:0a:35:05:2f:ec
> Address in environment is 00:0a:35:00:22:19
> eth0: ethernet at ff0e0000
> Hit any key to stop autoboot: 0
> ZynqMP> tftpboot 0x3000000 rdubey/sp01new.img
> Using ethernet at ff0e0000 device
> TFTP from server 172.19.0.3; our IP address is 172.19.2.40
> Filename 'rdubey/sp01new.img'.
> Load address: 0x3000000
> Loading: ####
> 1.7 MiB/s
> done
> Bytes transferred = 50978 (c722 hex)
> ZynqMP> bootm 0x3000000 ; reset
> ## Booting kernel from Legacy Image at 03000000 ...
> Image Name: RTEMS
> Image Type: ARM RTEMS Kernel Image (gzip compressed)
> Data Size: 50914 Bytes = 49.7 KiB
> Load Address: 00300000
> Entry Point: 00300000
> Verifying Checksum ... OK
> Uncompressing Kernel Image ... OK
> ## Transferring control to RTEMS (at address 00300000) ...
> "Synchronous Abort" handler, esr 0x02000000
> elr: ffffffff90593000 lr : 0000000010097a90 (reloc)
> elr: 0000000000300000 lr : 000000007fe04a90
> x0 : 000000007ddacf58 x1 : 0000000000000000
> x2 : 0000000000006802 x3 : 0000000000000020
> x4 : 0000000000000000 x5 : 0000000000000030
> x6 : 000000007fe7e9cd x7 : 000000000000000f
> x8 : 0000000000000038 x9 : 0000000000000008
> x10: 000000007ddbd530 x11: 00000000ffffffd0
> x12: 0000000000000000 x13: 0000000000000200
> x14: 0000000000000001 x15: 0000000000000008
> x16: 000000000000003f x17: 000000000000009a
> x18: 000000007ddacde8 x19: 0000000000300000
> x20: 000000007fead720 x21: 000000007fe04a20
> x22: 000000000000071f x23: 000000007fe04a20
> x24: 0000000000000001 x25: 000000007ddbd2f8
> x26: 000000007fe9ac18 x27: 0000000000300000
> x28: 0000000003000040 x29: 000000007dda07c0
> Resetting CPU ...
> ### ERROR ### Please RESET the board ###
> Can this be about the load address being at 0x00300000 and the .img
> being fetched at 0x3000000?
> On Wed, Apr 14, 2021 at 7:08 PM <Jan.Sommer at dlr.de
> <mailto:Jan.Sommer at dlr.de>> wrote:
> Hi Richi,
> In your log it says:
> Image Type: ARM Linux Kernel Image (gzip compressed)
> At least for our zedboard devices we use the following main
> options for mkimage.
> mkimage -A arm -O rtems -T kernel
> Which yields for me:
> IIRC the difference between -O rtems and -O linux is subtle, but
> maybe that helps.
> Best regards,
> Jan
> *From:* devel <devel-bounces at rtems.org
> <mailto:devel-bounces at rtems.org>> *On Behalf Of *Richi Dubey
> *Sent:* Wednesday, April 14, 2021 3:22 PM
> *To:* Kinsey Moore <kinsey.moore at oarcorp.com
> <mailto:kinsey.moore at oarcorp.com>>
> *Cc:* rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
> <devel at rtems.org <mailto:devel at rtems.org>>
> *Subject:* Re: Booting a rtems exe on Zynq UltraScale+ MPSoC
> ZCU106 board
> Trying to boot directly from the .img file also fails:
> ZynqMP> tftpboot 0x3000000 rdubey/sp01.img
> Filename 'rdubey/sp01.img'.
> Loading: ####
> 6.1 MiB/s
> done
> Image Name: RTEMS
> FDT and ATAGS support not compiled in - hanging
> What can I do now?
> On Wed, Apr 14, 2021 at 6:11 PM Kinsey Moore
> <kinsey.moore at oarcorp.com <mailto:kinsey.moore at oarcorp.com>> wrote:
> If you’re only running RTEMS, you should be able to drop the
> FDT commands since that what appears to be causing the problem
> and I don’t think that the arm/xilinx_zynqmp BSP uses it at all.
> Kinsey
> *From:*Richi Dubey <richidubey at gmail.com
> <mailto:richidubey at gmail.com>>
> *Sent:* Wednesday, April 14, 2021 01:01
> <mailto:kinsey.moore at oarcorp.com>>; rtems-devel at rtems.org
> <mailto:rtems-devel at rtems.org> <devel at rtems.org
> *Subject:* Booting a rtems exe on Zynq UltraScale+ MPSoC
> ZCU106 board
> Hi,
> I followed the 8.2.23 docs
> <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#xilinx-zynqmp> to
> build rtems for the xilinx_zynqmp_ultra96 bsp since it was the
> only bsp corresponding to xilinx-zynqmp in the rtems-bsp.
> Then I followed the boot via Uboot section 8.2.1.1 on docs
> <https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#boot-via-u-boot>,
> but the uboot on zcu106 does not have a run loadfdt command,
> and its alternative is fdt addr [address]. But something is
> wrong, I cannot run the sp01.img file:
> With fdt:
> Loading: ####
> 6.9 MiB/s
> done
> ZynqMP> fdt addr 0x2A00000
> ZynqMP> bootm 0x3000000 - 0x2A00000 ; reset
> Image Name: RTEMS
> ## Flattened Device Tree blob at 02a00000
> Booting using the fdt blob at 0x2a00000
> Loading Device Tree to 0000000007ff1000, end
> 0000000007fff257 ... OK
> fdt_find_or_add_subnode: chosen: FDT_ERR_BADSTRUCTURE
> ERROR: /chosen node create failed
> - must RESET the board to recover.
> FDT creation failed! hanging...### ERROR ### Please RESET the
> board ###
> With loading the system.dtb that I generally use for loading
> yocto linux images:
> ZynqMP> tftpboot 0x2A00000 rdubey/system.dtb
> TFTP from server 172.19.0.3; our IP address is 172.19.253.142
> Filename 'rdubey/system.dtb'.
> Load address: 0x2a00000
> Loading: ###T #
> 8.8 KiB/s
> done
> Bytes transferred = 45656 (b258 hex)
> Loading: ####
> 1.7 MiB/s
> done
> Image Name: RTEMS
> Starting kernel ...
> elr: ffffffff90593000 lr : 0000000010081868 (reloc)
> elr: 0000000000300000 lr : 000000007fdee868
> x0 : 0000000000000000 x1 : 0000000000000000
> x2 : 0000000007ff1000 x3 : 0000000000000000
> x4 : 0000000000300000 x5 : 0000000000000000
> x6 : 0000000000000008 x7 : 0000000000000000
> x8 : 000000007dda0650 x9 : 0000000001008000
> x10: 000000000a200023 x11: 0000000000000002
> x12: 0000000000000002 x13: 00000000000096f4
> x14: 000000007dda06ac x15: 000000007fdee224
> x16: 0000000000000002 x17: 0000000007fff258
> x18: 000000007ddacde8 x19: 000000007fead720
> x20: 0000000000000000 x21: 0000000000000400
> x22: 000000000000071f x23: 000000007fdeedb8
> x24: 0000000000000003 x25: 000000007ddbd378
> x28: 0000000003000040 x29: 000000007dda0790
> Resetting CPU ...
> What might be going wrong? zcu106 is a multi processor board,
> so do I need to do something special to run the sp01 test? I
> have not tested any other .exe (or .img) so far.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210414/328aa389/attachment-0001.html>
