[PATCH 0/1] grlib/genirq: Issue when enabling/disabling interrupt
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Apr 15 07:07:15 UTC 2021
Does someone have any objections to this patch?
I would like to push it to master and 5.
Or should we reach out to someone at Gaisler to check if it is ok?
Best regards,
    Jan
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of
> Gabriel.Moyano at dlr.de
> Sent: Tuesday, April 13, 2021 10:09 AM
> To: Moyano Heredia, Victor Gabriel <Gabriel.Moyano at dlr.de>;
> gedare at rtems.org
> Cc: devel at rtems.org
> Subject: AW: [PATCH 0/1] grlib/genirq: Issue when enabling/disabling
> interrupt
> >Yes, rtems 5 also has it. I can create a ticket.
> Here is the link to the ticket https://devel.rtems.org/ticket/4385#ticket.
> BTW the proposed solution for the master branch can be also applied to 5 as
> well.
> >Regarding the proposed solution, I wanted to start a thread for discussing it
> (maybe there is better was to do it).
> >>Is this a bug in rtems 5 also?
> >>If so, does it warrant a back-port fix and a ticket?
> >>On Mon, Apr 12, 2021 at 3:16 AM Moyano, Gabriel
> <gabriel.moyano at dlr.de> wrote:
> >>> Hello everyone,
> >>> I've found what can be an issue in the function genirq_set_active():
> under some conditions it can return a value greater than 1.
> >>> This function is used by genirq_enable() and genirq_disable() and both
> of them returns the value returned by genirq_set_active(). According to the
> documentation in genirq.h, they should return -1, 0 or 1.
> >>> When this issue can happen? If there are 3 entries in the list of IRQ and 2
> of them are already enabled, the variable `enabled` would be 2, because of
> `enabled += isrentry->enabled`.
> >>> As a possible solution, the value of `enabled` can changed to 1 if it's
> greater than 1 (see the patch) or maybe improve the search.
> >>> Thanks in advance,
> >>> Gabriel Moyano
> >>> Moyano, Gabriel (1):
> >>>   grlib/genirq: Taking into account that it could be more than one ISR
> >>>     enabled/disabled
> >>>  bsps/shared/grlib/irq/genirq.c | 5 +++++
> >>>  1 file changed, 5 insertions(+)
> devel mailing list
> devel at rtems.org
