[PATCH rtems-net-legacy] bsp_drivers: Use os.path for compatibility with non Unix host
Thu Apr 15 20:46:00 UTC 2021
On Thu, Apr 15, 2021 at 12:01 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> It has been less than 3 days, still pinging it. :)
> On Tue, Apr 13, 2021 at 11:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >  bsp_drivers.py | 26 +++++++++++++-------------
> >  1 file changed, 13 insertions(+), 13 deletions(-)
> > diff --git a/bsp_drivers.py b/bsp_drivers.py
> > index 3ca10c6..4a07847 100644
> > --- a/bsp_drivers.py
> > +++ b/bsp_drivers.py
> > @@ -36,18 +36,18 @@ def bsp_files(bld):
> >      include_dirs = {}
> >      include_files = []
> > -    special_case_dirs = {'atsamv': './bsps/arm/atsam',
> > -                         'lm32_evr': './bsps/lm32',
> > -                         'lpc24xx_ea': './bsps/arm/shared/'}
> > +    special_case_dirs = {'atsamv': 'bsps/arm/atsam',
should these be using also os.path.join(...)?
> > +                         'lm32_evr': 'bsps/lm32',
> > +                         'lpc24xx_ea': 'bsps/arm/shared/'}
> >      special_case_sources = {'leon2':
> > -                            ['./bsps/shared/grlib/net/network_interface_add.c',
> > -                             './bsps/shared/grlib/net/greth.c'],
> > +                            ['bsps/shared/grlib/net/network_interface_add.c',
> > +                             'bsps/shared/grlib/net/greth.c'],
> >                              'leon3':
> >                              'griscv':
> > -                             './bsps/shared/grlib/net/greth.c']}
> > +                             'bsps/shared/grlib/net/greth.c']}
> >      bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
> > @@ -57,9 +57,9 @@ def bsp_files(bld):
> >          include_dirs[bsp] = []
> >          source_files[bsp] = []
> >          if bsp not in special_case_dirs:
> > -            source_dir = os.walk(os.path.join('./bsps', arch, bsp))
> > +            source_dir = os.walk(os.path.join('bsps', arch, bsp))
> >          else:
> > -            source_dir = os.walk(special_case_dirs[bsp])
> > +            source_dir = os.walk(os.path.expanduser(special_case_dirs[bsp]))
> >          for root, dirs, files in source_dir:
> >              for name in files:
> >                  ext = os.path.splitext(name)[1]
> > @@ -69,6 +69,6 @@ def bsp_files(bld):
> >                      if root not in include_dirs[bsp]:
> >                          include_dirs[bsp].append(root)
> >              if bsp in special_case_sources:
> > -                source_files[bsp].extend(special_case_sources[bsp])
> > -        include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
> > +                source_files[bsp].extend([os.path.expanduser(f) for f in special_case_sources[bsp]])
> > +        include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
> >      return (include_dirs, source_files)
> > 2.26.2
