[PATCH rtems-net-legacy] bsp_drivers: Use os.path for compatibility with non Unix host
Vijay Kumar Banerjee
vijay at rtems.org
Thu Apr 15 18:01:06 UTC 2021
It has been less than 3 days, still pinging it. :)
On Tue, Apr 13, 2021 at 11:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> bsp_drivers.py | 26 +++++++++++++-------------
> 1 file changed, 13 insertions(+), 13 deletions(-)
> diff --git a/bsp_drivers.py b/bsp_drivers.py
> index 3ca10c6..4a07847 100644
> --- a/bsp_drivers.py
> +++ b/bsp_drivers.py
> @@ -36,18 +36,18 @@ def bsp_files(bld):
> include_dirs = {}
> include_files = []
> - special_case_dirs = {'atsamv': './bsps/arm/atsam',
> - 'lm32_evr': './bsps/lm32',
> - 'lpc24xx_ea': './bsps/arm/shared/'}
> + special_case_dirs = {'atsamv': 'bsps/arm/atsam',
> + 'lm32_evr': 'bsps/lm32',
> + 'lpc24xx_ea': 'bsps/arm/shared/'}
> special_case_sources = {'leon2':
> - ['./bsps/shared/grlib/net/network_interface_add.c',
> - './bsps/shared/grlib/net/greth.c'],
> + ['bsps/shared/grlib/net/network_interface_add.c',
> + 'bsps/shared/grlib/net/greth.c'],
> 'leon3':
> 'griscv':
> - './bsps/shared/grlib/net/greth.c']}
> + 'bsps/shared/grlib/net/greth.c']}
> bsp_list = bld.env.RTEMS_ARCH_BSP_LIST
> @@ -57,9 +57,9 @@ def bsp_files(bld):
> include_dirs[bsp] = []
> source_files[bsp] = []
> if bsp not in special_case_dirs:
> - source_dir = os.walk(os.path.join('./bsps', arch, bsp))
> + source_dir = os.walk(os.path.join('bsps', arch, bsp))
> else:
> - source_dir = os.walk(special_case_dirs[bsp])
> + source_dir = os.walk(os.path.expanduser(special_case_dirs[bsp]))
> for root, dirs, files in source_dir:
> for name in files:
> ext = os.path.splitext(name)[1]
> @@ -69,6 +69,6 @@ def bsp_files(bld):
> if root not in include_dirs[bsp]:
> include_dirs[bsp].append(root)
> if bsp in special_case_sources:
> - source_files[bsp].extend(special_case_sources[bsp])
> - include_dirs[bsp].append(os.path.join('./bsps', arch, bsp, 'net'))
> + source_files[bsp].extend([os.path.expanduser(f) for f in special_case_sources[bsp]])
> + include_dirs[bsp].append(os.path.join('bsps', arch, bsp, 'net'))
> return (include_dirs, source_files)
> 2.26.2
