[PATCH rtems-net-legacy] netlegacy: Remove telnetd build
Gedare Bloom
gedare at rtems.org
Thu Apr 15 20:48:17 UTC 2021
On Thu, Apr 15, 2021 at 12:01 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Telnet patches already reverted. Is this good to go?
Yes, except...
> On Tue, Apr 13, 2021 at 11:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > netlegacy.py | 13 ++-----------
> > testsuites/telnetd01/wscript | 5 +++++
> > 2 files changed, 7 insertions(+), 11 deletions(-)
> > diff --git a/netlegacy.py b/netlegacy.py
> > index ddd1db3..327d7cc 100644
> > --- a/netlegacy.py
> > +++ b/netlegacy.py
> > @@ -31,8 +31,7 @@ import os
> > source_files = []
> > include_files = {}
> > -exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps',
> > - 'telnetd']
> > +exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps']
should it be os.path.join(librpc, include)?
abolish all /
> > exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
> > for root, dirs, files in os.walk("."):
> > @@ -61,8 +60,6 @@ def build(bld):
> > bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
> > pppd_source = [os.path.join('pppd', s)
> > for s in os.listdir('pppd') if s[-2:] == '.c']
did you already fix the extension part of this one too?
this stuff can be done in a cleanup if they haven't been. Just trying
to find that OS-agnostic sweet spot still.
Do we have recommendations about this in our Python docs....
> > - telnetd_source = [os.path.join('telnetd', s)
> > - for s in os.listdir('telnetd') if s[-2:] == '.c']
> > nfs_source = []
> > for root, dirs, files in os.walk('nfsclient'):
> > for name in files:
> > @@ -120,12 +117,6 @@ def build(bld):
> > use='networking',
> > source=pppd_source)
> > - bld.stlib(target='telnetd',
> > - features='c',
> > - includes=ip,
> > - use='networking',
> > - source=telnetd_source)
> > bld.stlib(target='nfs',
> > features='c',
> > includes=ip,
> > @@ -133,7 +124,7 @@ def build(bld):
> > source=nfs_source)
> > bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > - ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > + ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
> > bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > 'include', 'libchip'),
> > install_file_list('bsps', 'include', 'libchip'))
> > diff --git a/testsuites/telnetd01/wscript b/testsuites/telnetd01/wscript
> > index 782c0f6..dc18737 100644
> > --- a/testsuites/telnetd01/wscript
> > +++ b/testsuites/telnetd01/wscript
> > @@ -38,6 +38,11 @@ def configure(conf):
> > def build(bld):
> > + arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > + bld.env.RTEMS_ARCH_BSP)
> > + lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > + bld.read_stlib('telnetd', paths=[lib_path])
> > bld.program(target='telnetd01.exe',
> > features='c cprogram',
> > cflags=['-O2', '-g'],
> > 2.26.2
