[PATCH rtems-net-legacy] netlegacy: Remove telnetd build
Vijay Kumar Banerjee vijay at rtems.org
Thu Apr 15 20:52:49 UTC 2021
On Thu, Apr 15, 2021 at 2:48 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 15, 2021 at 12:01 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > Telnet patches already reverted. Is this good to go?
> Yes, except...
> > On Tue, Apr 13, 2021 at 11:49 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >  netlegacy.py                 | 13 ++-----------
> > >  testsuites/telnetd01/wscript |  5 +++++
> > >  2 files changed, 7 insertions(+), 11 deletions(-)
> > > diff --git a/netlegacy.py b/netlegacy.py
> > > index ddd1db3..327d7cc 100644
> > > --- a/netlegacy.py
> > > +++ b/netlegacy.py
> > > @@ -31,8 +31,7 @@ import os
> > >  source_files = []
> > >  include_files = {}
> > > -exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps',
> > > -                'telnetd']
> > > +exclude_dirs = ['pppd', 'nfsclient', 'testsuites', 'librpc/include', 'bsps']
> should it be os.path.join(librpc, include)?
> abolish all /
Ok, I'll fix this.
> > >  exclude_headers = ['rtems-bsd-user-space.h', 'rtems-bsd-kernel-space.h']
> > >  for root, dirs, files in os.walk("."):
> > > @@ -61,8 +60,6 @@ def build(bld):
> > >      bsp = bld.env.RTEMS_ARCH_BSP.split('-')[-1]
> > >      pppd_source = [os.path.join('pppd', s)
> > >                     for s in os.listdir('pppd') if s[-2:] == '.c']
> did you already fix the extension part of this one too?
> this stuff can be done in a cleanup if they haven't been. Just trying
> to find that OS-agnostic sweet spot still.
This was cleaned up later. I can send an updated patch rebased to the
recently merged changes, this was fixed in the nfclient patch.
> Do we have recommendations about this in our Python docs....
I'm not sure, I didn't find anything here:
https://docs.rtems.org/branches/master/eng/python-devel.html
> > > -    telnetd_source = [os.path.join('telnetd', s)
> > > -                      for s in os.listdir('telnetd') if s[-2:] == '.c']
> > >      nfs_source = []
> > >      for root, dirs, files in os.walk('nfsclient'):
> > >          for name in files:
> > > @@ -120,12 +117,6 @@ def build(bld):
> > >                use='networking',
> > >                source=pppd_source)
> > > -    bld.stlib(target='telnetd',
> > > -              features='c',
> > > -              includes=ip,
> > > -              use='networking',
> > > -              source=telnetd_source)
> > >      bld.stlib(target='nfs',
> > >                features='c',
> > >                includes=ip,
> > > @@ -133,7 +124,7 @@ def build(bld):
> > >                source=nfs_source)
> > >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path),
> > > -                      ["libnetworking.a", 'libpppd.a', 'libtelnetd.a', 'libnfs.a'])
> > > +                      ["libnetworking.a", 'libpppd.a', 'libnfs.a'])
> > >      bld.install_files(os.path.join('${PREFIX}', arch_lib_path,
> > >                                     'include', 'libchip'),
> > >                        install_file_list('bsps', 'include', 'libchip'))
> > > diff --git a/testsuites/telnetd01/wscript b/testsuites/telnetd01/wscript
> > > index 782c0f6..dc18737 100644
> > > --- a/testsuites/telnetd01/wscript
> > > +++ b/testsuites/telnetd01/wscript
> > > @@ -38,6 +38,11 @@ def configure(conf):
> > >  def build(bld):
> > > +    arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> > > +                                            bld.env.RTEMS_ARCH_BSP)
> > > +    lib_path = os.path.join(bld.env.PREFIX, arch_lib_path)
> > > +    bld.read_stlib('telnetd', paths=[lib_path])
> > >      bld.program(target='telnetd01.exe',
> > >                  features='c cprogram',
> > >                  cflags=['-O2', '-g'],
> > > 2.26.2
