[PATCH] score: Allways check if a prio ceiling is defined
Sebastian Huber
Fri Apr 16 07:30:39 UTC 2021
Priority ceiling semaphores (in contrast to MrsP semaphores) have only
one priority ceiling which is defined for the home scheduler of the task
which created the semaphore. Always check during a semaphore seize that
the home scheduler of the calling task is equal to this scheduler.
This avoids a scheduler mismatch if the semphore is acquired after the
calling thread blocked on the semaphore.
cpukit/include/rtems/score/coremuteximpl.h | 20 ++++++++++----------
1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/score/coremuteximpl.h b/cpukit/include/rtems/score/coremuteximpl.h
index cbc1e720fb..6b5c240105 100644
--- a/cpukit/include/rtems/score/coremuteximpl.h
+++ b/cpukit/include/rtems/score/coremuteximpl.h
@@ -475,19 +475,19 @@ RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Seize(
_CORE_mutex_Acquire_critical( &the_mutex->Recursive.Mutex, queue_context );
- owner = _CORE_mutex_Get_owner( &the_mutex->Recursive.Mutex );
- if ( owner == NULL ) {
#if defined(RTEMS_SMP)
- if (
- _Thread_Scheduler_get_home( executing )
- != _CORE_ceiling_mutex_Get_scheduler( the_mutex )
- _CORE_mutex_Release( &the_mutex->Recursive.Mutex, queue_context );
- return STATUS_NOT_DEFINED;
+ if (
+ _Thread_Scheduler_get_home( executing )
+ != _CORE_ceiling_mutex_Get_scheduler( the_mutex )
+ _CORE_mutex_Release( &the_mutex->Recursive.Mutex, queue_context );
+ return STATUS_NOT_DEFINED;
#endif
+ owner = _CORE_mutex_Get_owner( &the_mutex->Recursive.Mutex );
+ if ( owner == NULL ) {
_Thread_queue_Context_clear_priority_updates( queue_context );
return _CORE_ceiling_mutex_Set_owner(
the_mutex,
2.26.2
