[PATCH] c-user: Document rtems_semaphore_obtain() errors
Gedare Bloom
gedare at rtems.org
Fri Apr 16 14:06:35 UTC 2021
ok
On Fri, Apr 16, 2021 at 12:59 AM Sebastian Huber
> Update #3993.
> c-user/semaphore/directives.rst | 8 ++++++++
> 1 file changed, 8 insertions(+)
> diff --git a/c-user/semaphore/directives.rst b/c-user/semaphore/directives.rst
> index 54f40a4..7c2a9c8 100644
> --- a/c-user/semaphore/directives.rst
> +++ b/c-user/semaphore/directives.rst
> @@ -525,9 +525,17 @@ scheduler.
> :c:macro:`RTEMS_INVALID_ID`
> There was no semaphore associated with the identifier specified by ``id``.
> +:c:macro:`RTEMS_NOT_DEFINED`
> + The semaphore uses a priority ceiling and there was no priority ceiling
> + defined for the :term:`home scheduler` of the calling task.
> :c:macro:`RTEMS_UNSATISFIED`
> The semaphore could not be obtained immediately.
> +:c:macro:`RTEMS_INVALID_PRIORITY`
> + The semaphore uses a priority ceiling and the calling task had a current
> + priority less than the priority ceiling.
> :c:macro:`RTEMS_INCORRECT_STATE`
> Acquiring of the local, binary semaphore by the calling task would have
> cased a deadlock.
> 2.26.2
> devel mailing list
> devel at rtems.org
