[PATCH v1] c-user: Add documentation for exception mapping
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Apr 16 13:05:36 UTC 2021
On 4/16/2021 02:13, Sebastian Huber wrote:
> On 14/04/2021 17:47, Kinsey Moore wrote:
>> +.. _CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING:
>> +CONFIGURE_APPLICATION_NEEDS_EXCEPTION_TO_SIGNAL_MAPPING
> What about:
> CONFIGURE_ENABLE_EXCEPTION_TO_SIGNAL_MAPPINGS
> This "application needs" is a bit superfluous since all the configure
> defines express application needs. I guess you get a linker error on
> all architectures except aarch64 if you use this option?
I'll update my patches to that symbol and adjust the documentation
accordingly.
Yes, that's currently the case for non-aarch64 platforms. The test is
set to require aarch64 as a result.
Kinsey
