[PATCH v1] c-user: Add documentation for exception mapping
Fri Apr 16 13:19:59 UTC 2021
On 16/04/2021 15:05, Kinsey Moore wrote:
> Yes, that's currently the case for non-aarch64 platforms. The test is
> set to require aarch64 as a result.
How do you get this information from the documentation?
In case this is something which potentially every CPU port can
implement, then the implementation interface should be in the _CPU_*
scope. You may also add something like
CPU_HAS_EXCEPTION_TO_SIGNAL_MAPPINGS_SUPPORT TRUE/FALSE.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
