[PATCH RTEMS v2 0/1] bsp/beagle: Refactored i2c driver and Updated
Christian Mauderer oss at c-mauderer.de
Sun Apr 18 11:24:46 UTC 2021
Hello Niteesh,
sorry for not taking a look earlier.
The patches seem OK for me. Just a tiny change request:
I know that I suggested the "rtems,path" for the device tree. When
testing I noted that we have the rtems-i2c driver in libbsd which is
more or less just a compatibility layer between libbsd and RTEMS. This
driver uses "rtems,i2c-path" instead of "rtems,path". Maybe you could
add one of these two solutions:
1. Either change "rtems,path" to "rtems,i2c-path" in your driver.
2. Or add "rtems,path" as an additional possible path to
"libbsd/rtemsbsd/sys/dev/iicbus/rtems-i2c.c". Basically that would just
mean that in the error case of the current OF_getprop_alloc you just try
the "rtems,path" before failing.
I really like the short and universal name of "rtems,path" so I would
prefer the second solution. But I would be OK with the first one too.
Best regards
Christian
On 18/04/2021 06:20, Niteesh G. S. wrote:
> ping.
> On Sun, Apr 11, 2021 at 12:45 AM G S Niteesh Babu <niteesh.gs at gmail.com
> <mailto:niteesh.gs at gmail.com>> wrote:
>     The following two patches update the Beagle BSP i2c driver to use
>     device tree based initialization and the documentation related to
>     it.
>     G S Niteesh Babu (1):
>        bsps/beagle: Refactored i2c driver
>       bsps/arm/beagle/i2c/bbb-i2c.c     | 122 ++++++++++++++++++------------
>       bsps/arm/beagle/include/bsp.h     |   4 +
>       bsps/arm/beagle/include/bsp/i2c.h |  32 +-------
>       bsps/arm/beagle/start/bspstart.c  |  51 +++++++++----
>       4 files changed, 114 insertions(+), 95 deletions(-)
>     2.17.1
> devel mailing list
> devel at rtems.org
