[PATCH RTEMS v2 0/1] bsp/beagle: Refactored i2c driver and Updated
Niteesh G. S.
niteesh.gs at gmail.com
Sun Apr 18 15:19:22 UTC 2021
Hello Christian,
On Sun, Apr 18, 2021 at 4:54 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Niteesh,
> sorry for not taking a look earlier.
No problem
> The patches seem OK for me. Just a tiny change request:
> I know that I suggested the "rtems,path" for the device tree. When
> testing I noted that we have the rtems-i2c driver in libbsd which is
> more or less just a compatibility layer between libbsd and RTEMS. This
> driver uses "rtems,i2c-path" instead of "rtems,path". Maybe you could
> add one of these two solutions:
> 1. Either change "rtems,path" to "rtems,i2c-path" in your driver.
> 2. Or add "rtems,path" as an additional possible path to
> "libbsd/rtemsbsd/sys/dev/iicbus/rtems-i2c.c". Basically that would just
> mean that in the error case of the current OF_getprop_alloc you just try
> the "rtems,path" before failing.
> I really like the short and universal name of "rtems,path" so I would
> prefer the second solution. But I would be OK with the first one too.
I have sent a patch for your preferred solution.
Patches that are pending are:
1) https://lists.rtems.org/pipermail/devel/2021-April/066458.html
2) https://lists.rtems.org/pipermail/devel/2021-April/066460.html
3) https://lists.rtems.org/pipermail/devel/2021-April/066629.html
Thanks,
Niteesh.
> Best regards
> Christian
> On 18/04/2021 06:20, Niteesh G. S. wrote:
> > ping.
> > On Sun, Apr 11, 2021 at 12:45 AM G S Niteesh Babu <niteesh.gs at gmail.com
> > <mailto:niteesh.gs at gmail.com>> wrote:
> > The following two patches update the Beagle BSP i2c driver to use
> > device tree based initialization and the documentation related to
> > it.
> > G S Niteesh Babu (1):
> > bsps/beagle: Refactored i2c driver
> > bsps/arm/beagle/i2c/bbb-i2c.c | 122
> > bsps/arm/beagle/include/bsp.h | 4 +
> > bsps/arm/beagle/include/bsp/i2c.h | 32 +-------
> > bsps/arm/beagle/start/bspstart.c | 51 +++++++++----
> > 4 files changed, 114 insertions(+), 95 deletions(-)
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210418/034c6014/attachment.html>
