[PATCH] clock:_TOD_To_seconds(): Fix year 2514 overflow
Gedare Bloom
gedare at rtems.org
Mon Apr 19 16:45:39 UTC 2021
It is reasonable. Let's capture the analysis. I thought there was a
place we had notes related to different time source overflows, but I
can't find it quickly
On Mon, Apr 19, 2021 at 9:44 AM Sebastian Huber
> On 13/04/2021 18:03, Sebastian Huber wrote:
> > Hello,
> > On 08/04/2021 15:41, Frank Kuehndel wrote:
> >> + * @brief Latest year to which a time of day can be initialized.
> >> + * The following constant defines the latest year to which an
> >> + * RTEMS time of day can be set using rtems_clock_set().
> >> + * 32 bits can accept as latest point in time 2106-Feb-7 6:28:15
> >> + * but to simplify the implementation, is was decided to only
> >> + * check that the year is not greater than the year of this constant.
> >> + * The internal realtime clock can run centuries longer but in
> >> + * contrast to the POSIX API, the RTEMS Classic API does not
> >> + * support this for efficiency reasons.
> >> +#define TOD_LATEST_YEAR 2105
> > any objections to use this approach? If we want to support years after
> > 2105 in the Classic API, then we would need 64-bit values and
> > calculations in several places. I think an RTEMS system which operates
> > after 2105 is currently a bit unrealistic.
> > If we limit the time frame to the year 2100 we could simplify
> > _TOD_Validate() a bit more since all years % 4 == 0 are leap years in
> > the range 1988 to 2100 (exclusive).
> If there are no objections, then I will check this in on Wednesday and
> send a documentation update.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
