OS Neutrality in Python Development Guidelines?
Gedare Bloom
gedare at rtems.org
Mon Apr 19 16:48:21 UTC 2021
On Mon, Apr 19, 2021 at 9:36 AM Sebastian Huber
> On 19/04/2021 00:29, Chris Johns wrote:
> > On 16/4/21 3:28 pm, Sebastian Huber wrote:
> >> On 15/04/2021 22:58, Gedare Bloom wrote:
> >>> I guess we should define something to add here? Is anything written
> >>> somewhere we can adopt?
> >> the spirit of the Python guide is to have rules which are enforced by tools.
> > I see a guide as a means to provide robust and portable code in a common style
> > where we document and learn from our experiences.
> I am not against a couple of best practice rules.
> > Any forced line like needing a
> > tool would create an artificial barrier where needed rules are not added because
> > we do not have a tool. I doubt any of us would want that to happen.
> >> If
> >> a certain component should run on platform X, then I think some CI system should
> >> be in place which runs the test suite on platform X.
> > This is hard to do, costs money and is only as good as a tests. It is important
> > but we should also use reviews as a way to catch issues.
> In github for example, you have test runners available for Linux,
> Windows and macOS. Testing is never perfect, but no tests at all is
> really not that great.
> >>> Was this considered at all under the pre-qual effort (which stimulated
> >>> these guidelines in the first place)? Do we have a Windows blind spot
> >>> in our Python code bases?
> >> The Python modules in rtems-central should run on Windows, however, I never
> >> tested this.
> > A random pick of a file and a brief scan ...
> > https://git.rtems.org/rtems-central/tree/rtemsspec/interface.py#n313
> There is no issue in this line.
I believe some can configure their git to inject \n\r on clone/pull
and fixes it up on commit. I have to do this for example to use
Windows source files in some projects where the IDE is only available
there.
> We probably have to use newline="\n" for the open() calls which write
> files. However, getting this to work on Window is currently not on my
> high priority list.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
