[PATCH rtems-docs] legacy-networking: Add note with build instructions for rtems-net-legacy
    Vijay Kumar Banerjee
    vijay at rtems.org
    Mon Apr 19 18:12:03 UTC 2021
 legacy-networking/index.rst       |  1 +
 legacy-networking/quick_start.rst | 29 +++++++++++++++++++++++++++++
 2 files changed, 30 insertions(+)
 create mode 100644 legacy-networking/quick_start.rst
diff --git a/legacy-networking/index.rst b/legacy-networking/index.rst
index b85119d..acbfd35 100644
--- a/legacy-networking/index.rst
+++ b/legacy-networking/index.rst
@@ -22,6 +22,7 @@ RTEMS Legacy Network User Manual (|version|).
 	:numbered:
 	preface
+	quick_start
 	network_task_structure
 	networking_driver
 	using_networking_rtems_app
diff --git a/legacy-networking/quick_start.rst b/legacy-networking/quick_start.rst
new file mode 100644
index 0000000..97ea71c
--- /dev/null
+++ b/legacy-networking/quick_start.rst
@@ -0,0 +1,29 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+Quick Start
+This legacy networking is now a standalone repository and needs to be built
+separately.
+The repository can be found here: https://git.rtems.org/rtems-net-legacy/
+The RSB build recipe for legacy networking is:
+  .. code-block:: shell
+        ../source-builder/sb-set-builder \
+        --prefix=/path/to/rtems/prefix \
+        6/rtems-net-legacy \
+        --host=powerpc-rtems6 \
+        --with-rtems-bsp=beatnik
+Manually building the rtems-net-legacy repo:
+        git submodule init
+        git submodule update
+        ./waf configure --prefix=/path/to/rtems/prefix
+        ./waf
+        ./waf install
2.26.2
