[PATCH rtems-docs] legacy-networking: Add note with build instructions for rtems-net-legacy
Vijay Kumar Banerjee
vijay at rtems.org
Thu Apr 22 18:08:25 UTC 2021
ping. :)
On Mon, Apr 19, 2021 at 12:12 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> legacy-networking/index.rst | 1 +
> legacy-networking/quick_start.rst | 29 +++++++++++++++++++++++++++++
> 2 files changed, 30 insertions(+)
> create mode 100644 legacy-networking/quick_start.rst
> diff --git a/legacy-networking/index.rst b/legacy-networking/index.rst
> index b85119d..acbfd35 100644
> --- a/legacy-networking/index.rst
> +++ b/legacy-networking/index.rst
> @@ -22,6 +22,7 @@ RTEMS Legacy Network User Manual (|version|).
> :numbered:
> preface
> + quick_start
> network_task_structure
> networking_driver
> using_networking_rtems_app
> diff --git a/legacy-networking/quick_start.rst b/legacy-networking/quick_start.rst
> new file mode 100644
> index 0000000..97ea71c
> --- /dev/null
> +++ b/legacy-networking/quick_start.rst
> @@ -0,0 +1,29 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +Quick Start
> +This legacy networking is now a standalone repository and needs to be built
> +separately.
> +The repository can be found here: https://git.rtems.org/rtems-net-legacy/
> +The RSB build recipe for legacy networking is:
> + .. code-block:: shell
> + ../source-builder/sb-set-builder \
> + --prefix=/path/to/rtems/prefix \
> + 6/rtems-net-legacy \
> + --host=powerpc-rtems6 \
> + --with-rtems-bsp=beatnik
> +Manually building the rtems-net-legacy repo:
> + git submodule init
> + git submodule update
> + ./waf configure --prefix=/path/to/rtems/prefix
> + ./waf
> + ./waf install
> 2.26.2
