[PATCH] bsps/arm: Set MSP in ARMv7-M start code
Sebastian Huber
Tue Apr 20 05:28:09 UTC 2021
This helps if applications are started by a boot loader.
bsps/arm/shared/start/start.S | 8 ++++++++
1 file changed, 8 insertions(+)
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index 50bf1d4841..bd623178ed 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -553,6 +553,14 @@ _start:
#endif
ldr sp, =_ISR_Stack_area_end
+ * Set the Main Stack Pointer (MSP) to the ISR stack area end just in
+ * case we run using the Process Stack Pointer (PSP).
+ mov r0, sp
+ msr msp, r0
ldr lr, =bsp_start_hook_0_done + 1
b bsp_start_hook_0
2.26.2
