[PATCH rtems-docs] legacy-networking: Add note with build instructions for rtems-net-legacy
Vijay Kumar Banerjee vijay at rtems.org
Fri Apr 23 01:59:19 UTC 2021
On Thu, Apr 22, 2021 at 12:18 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 22, 2021 at 12:08 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > ping. :)
> > On Mon, Apr 19, 2021 at 12:12 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > >  legacy-networking/index.rst       |  1 +
> > >  legacy-networking/quick_start.rst | 29 +++++++++++++++++++++++++++++
> > >  2 files changed, 30 insertions(+)
> > >  create mode 100644 legacy-networking/quick_start.rst
> > > diff --git a/legacy-networking/index.rst b/legacy-networking/index.rst
> > > index b85119d..acbfd35 100644
> > > --- a/legacy-networking/index.rst
> > > +++ b/legacy-networking/index.rst
> > > @@ -22,6 +22,7 @@ RTEMS Legacy Network User Manual (|version|).
> > >         :numbered:
> > >         preface
> > > +       quick_start
> > >         network_task_structure
> > >         networking_driver
> > >         using_networking_rtems_app
> > > diff --git a/legacy-networking/quick_start.rst b/legacy-networking/quick_start.rst
> > > new file mode 100644
> > > index 0000000..97ea71c
> > > --- /dev/null
> > > +++ b/legacy-networking/quick_start.rst
> > > @@ -0,0 +1,29 @@
> > > +.. SPDX-License-Identifier: CC-BY-SA-4.0
> > > +Quick Start
> > > +This legacy networking is now a standalone repository and needs to be built
> > > +separately.
> > > +The repository can be found here: https://git.rtems.org/rtems-net-legacy/
> > > +The RSB build recipe for legacy networking is:
> I guess it should be obvious, but maybe make a clarification like "on
> the powerpc beatnik BSP with rtems version 6 for example is:"
Thanks for the review. I sent a v2 with these additions.
Best regards,
Vijay
> > > +  .. code-block:: shell
> > > +        ../source-builder/sb-set-builder \
> > > +        --prefix=/path/to/rtems/prefix \
> > > +        6/rtems-net-legacy \
> > > +        --host=powerpc-rtems6 \
> > > +        --with-rtems-bsp=beatnik
> > > +Manually building the rtems-net-legacy repo:
> > > +        git submodule init
> > > +        git submodule update
> > > +        ./waf configure --prefix=/path/to/rtems/prefix
> > > +        ./waf
> > > +        ./waf install
> And maybe indicate that more details can be found in the README.waf?
> > > 2.26.2
> > devel mailing list
> > devel at rtems.org
