[PATCH 1/8] c-user: Split up initialization manager
Wed Apr 21 13:49:59 UTC 2021
This makes it easier to automatically generate parts of the module
documentation in the future.
Update #3993.
 c-user/index.rst                              |  2 +-
 c-user/initialization/background.rst          | 48 +++++++++
 c-user/initialization/directives.rst          | 41 ++++++++
 c-user/initialization/index.rst               | 15 +++
 c-user/initialization/introduction.rst        | 15 +++
 .../operations.rst}                           | 98 -------------------
 6 files changed, 120 insertions(+), 99 deletions(-)
 create mode 100644 c-user/initialization/background.rst
 create mode 100644 c-user/initialization/directives.rst
 create mode 100644 c-user/initialization/index.rst
 create mode 100644 c-user/initialization/introduction.rst
 rename c-user/{initialization.rst => initialization/operations.rst} (80%)
diff --git a/c-user/index.rst b/c-user/index.rst
index 2f8109a..0a05c75 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -29,7 +29,7 @@ RTEMS Classic API Guide (|version|).
 	key_concepts
 	rtems_data_types
 	scheduling-concepts/index
-	initialization
+	initialization/index
 	task/index
 	interrupt/index
 	clock/index
diff --git a/c-user/initialization/background.rst b/c-user/initialization/background.rst
new file mode 100644
index 0000000..36d8ebd
--- /dev/null
+++ b/c-user/initialization/background.rst
@@ -0,0 +1,48 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Background
+.. index:: initialization tasks
+Initialization Tasks
+Initialization task(s) are the mechanism by which RTEMS transfers initial
+control to the user's application.  Initialization tasks differ from other
+application tasks in that they are defined in the User Initialization Tasks
+Table and automatically created and started by RTEMS as part of its
+initialization sequence.  Since the initialization tasks are scheduled using
+the same algorithm as all other RTEMS tasks, they must be configured at a
+priority and mode which will ensure that they will complete execution before
+other application tasks execute.  Although there is no upper limit on the
+number of initialization tasks, an application is required to define at least
+one.
+A typical initialization task will create and start the static set of
+application tasks.  It may also create any other objects used by the
+application.  Initialization tasks which only perform initialization should
+delete themselves upon completion to free resources for other tasks.
+Initialization tasks may transform themselves into a "normal" application task.
+This transformation typically involves changing priority and execution mode.
+RTEMS does not automatically delete the initialization tasks.
+The Idle Task
+The Idle Task is the lowest priority task in a system and executes only when no
+other task is ready to execute.  The default implementation of this task
+consists of an infinite loop. RTEMS allows the Idle Task body to be replaced by
+a CPU specific implementation, a BSP specific implementation or an application
+specific implementation.
+The Idle Task is preemptible and *WILL* be preempted when any other task is
+made ready to execute.  This characteristic is critical to the overall behavior
+of any application.
+Initialization Manager Failure
+System initialization errors are fatal.  See :ref:`internal_errors`.
diff --git a/c-user/initialization/directives.rst b/c-user/initialization/directives.rst
index 0000000..97dea46
--- /dev/null
+++ b/c-user/initialization/directives.rst
@@ -0,0 +1,41 @@
+Directives
+This section details the Initialization Manager's directives.  A subsection is
+dedicated to each of this manager's directives and describes the calling
+sequence, related constants, usage, and status codes.
+.. raw:: latex
+   \clearpage
+.. index:: initialize RTEMS
+.. index:: start multitasking
+.. index:: rtems_initialize_executive
+.. _rtems_initialize_executive:
+INITIALIZE_EXECUTIVE - Initialize RTEMS
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_initialize_executive(void);
+DIRECTIVE STATUS CODES:
+    NONE - This function will not return to the caller.
+DESCRIPTION:
+    Iterates through the system initialization linker set and invokes the
+    registered handlers.  The final step is to start multitasking.
+NOTES:
+    This directive should be called by :c:func:`boot_card()` only.
+    This directive *does not return* to the caller.  Errors in the
+    initialization sequence are usually fatal and lead to a system termination.
diff --git a/c-user/initialization/index.rst b/c-user/initialization/index.rst
index 0000000..b41fcdd
--- /dev/null
+++ b/c-user/initialization/index.rst
@@ -0,0 +1,15 @@
+.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. _RTEMSAPIClassicInit:
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/initialization/introduction.rst b/c-user/initialization/introduction.rst
index 0000000..ae14fb0
--- /dev/null
+++ b/c-user/initialization/introduction.rst
@@ -0,0 +1,15 @@
+Introduction
+The Initialization Manager is responsible for initializing the Board Support
+Package, RTEMS, device drivers, the root filesystem and the application.  The
+:ref:`Fatal Error Manager <fatal_error_manager>` is responsible for the system
+shutdown.
+The Initialization Manager provides only one directive:
+- :ref:`rtems_initialize_executive`
diff --git a/c-user/initialization.rst b/c-user/initialization/operations.rst
similarity index 80%
rename from c-user/initialization.rst
rename to c-user/initialization/operations.rst
index fa7afb5..db5c94b 100644
--- a/c-user/initialization.rst
+++ b/c-user/initialization/operations.rst
@@ -2,66 +2,6 @@
-Initialization Manager
-Introduction
-The Initialization Manager is responsible for initializing the Board Support
-Package, RTEMS, device drivers, the root filesystem and the application.  The
-:ref:`Fatal Error Manager <fatal_error_manager>` is responsible for the system
-shutdown.
-The Initialization Manager provides only one directive:
-- rtems_initialize_executive_ - Initialize RTEMS
-Background
-.. index:: initialization tasks
-Initialization Tasks
-Initialization task(s) are the mechanism by which RTEMS transfers initial
-control to the user's application.  Initialization tasks differ from other
-application tasks in that they are defined in the User Initialization Tasks
-Table and automatically created and started by RTEMS as part of its
-initialization sequence.  Since the initialization tasks are scheduled using
-the same algorithm as all other RTEMS tasks, they must be configured at a
-priority and mode which will ensure that they will complete execution before
-other application tasks execute.  Although there is no upper limit on the
-number of initialization tasks, an application is required to define at least
-one.
-A typical initialization task will create and start the static set of
-application tasks.  It may also create any other objects used by the
-application.  Initialization tasks which only perform initialization should
-delete themselves upon completion to free resources for other tasks.
-Initialization tasks may transform themselves into a "normal" application task.
-This transformation typically involves changing priority and execution mode.
-RTEMS does not automatically delete the initialization tasks.
-The Idle Task
-The Idle Task is the lowest priority task in a system and executes only when no
-other task is ready to execute.  The default implementation of this task
-consists of an infinite loop. RTEMS allows the Idle Task body to be replaced by
-a CPU specific implementation, a BSP specific implementation or an application
-specific implementation.
-The Idle Task is preemptible and *WILL* be preempted when any other task is
-made ready to execute.  This characteristic is critical to the overall behavior
-of any application.
-Initialization Manager Failure
-System initialization errors are fatal.  See :ref:`internal_errors`.
 Operations
@@ -418,41 +358,3 @@ should output:
     c()
     b()
     A:A()
-Directives
-This section details the Initialization Manager's directives.  A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
-.. raw:: latex
-   \clearpage
-.. index:: initialize RTEMS
-.. index:: start multitasking
-.. index:: rtems_initialize_executive
-.. _rtems_initialize_executive:
-INITIALIZE_EXECUTIVE - Initialize RTEMS
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_initialize_executive(void);
-DIRECTIVE STATUS CODES:
-    NONE - This function will not return to the caller.
-DESCRIPTION:
-    Iterates through the system initialization linker set and invokes the
-    registered handlers.  The final step is to start multitasking.
-NOTES:
-    This directive should be called by :c:func:`boot_card()` only.
-    This directive *does not return* to the caller.  Errors in the
-    initialization sequence are usually fatal and lead to a system termination.
2.26.2
