[PATCH 2/8] c-user: Split up fatal error manager
Wed Apr 21 13:50:00 UTC 2021
This makes it easier to automatically generate parts of the module
documentation in the future.
Update #3993.
 .../background.rst}                           | 300 ------------------
 c-user/fatal-error/directives.rst             | 226 +++++++++++++
 c-user/fatal-error/index.rst                  |  17 +
 c-user/fatal-error/introduction.rst           |  25 ++
 c-user/fatal-error/operations.rst             |  51 +++
 c-user/index.rst                              |   2 +-
 c-user/initialization/introduction.rst        |   2 +-
 7 files changed, 321 insertions(+), 302 deletions(-)
 rename c-user/{fatal_error.rst => fatal-error/background.rst} (62%)
 create mode 100644 c-user/fatal-error/directives.rst
 create mode 100644 c-user/fatal-error/index.rst
 create mode 100644 c-user/fatal-error/introduction.rst
 create mode 100644 c-user/fatal-error/operations.rst
diff --git a/c-user/fatal_error.rst b/c-user/fatal-error/background.rst
similarity index 62%
rename from c-user/fatal_error.rst
rename to c-user/fatal-error/background.rst
index 81cfa0c..571da10 100644
--- a/c-user/fatal_error.rst
+++ b/c-user/fatal-error/background.rst
@@ -2,35 +2,6 @@
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. index:: fatal errors
-.. _fatal_error_manager:
-Fatal Error Manager
-Introduction
-The fatal error manager processes all fatal or irrecoverable errors and other
-sources of system termination (for example after :c:func:`exit()`).  Fatal
-errors are identified by the (fatal source, error code) pair.  The directives
-provided by the fatal error manager are:
-- rtems_fatal_ - Invoke the fatal error handler
-- rtems_panic_ - Print a message and invoke the fatal error handler
-- rtems_shutdown_executive_ - Shutdown RTEMS
-- rtems_exception_frame_print_ - Print the CPU exception frame
-- rtems_fatal_source_text_ - Return the fatal source text
-- rtems_internal_error_text_ - Return the error code text
-- rtems_fatal_error_occurred_ - Invoke the fatal error handler (deprecated)
 Background
@@ -383,274 +354,3 @@ INTERNAL_ERROR_TOO_LARGE_TLS_SIZE (41)
     :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE <CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE>`.
     You can get the thread-local storage size of an application using the RTEMS
     tool ``rtems-execinfo``.
-Operations
-.. index:: _Terminate
-.. _Terminate:
-Announcing a Fatal Error
-The :c:func:`_Terminate()` internal error handler is invoked when the
-application or the executive itself determines that a fatal error has occurred
-or a final system state is reached (for example after :c:func:`rtems_fatal()`
-or :c:func:`exit()`).
-The first action of the internal error handler is to call the fatal extension of
-the user extensions.  For the initial extensions the following conditions are
-required
-- a valid stack pointer and enough stack space,
-- a valid code memory, and
-- valid read-only data.
-For the initial extensions the read-write data (including .bss segment) is not
-required on single processor configurations.  In SMP configurations, however,
-the read-write data must be initialized since this function must determine the
-state of the other processors and request them to shut-down if necessary.
-Non-initial extensions require in addition valid read-write data.  The board
-support package (BSP) may install an initial extension that performs a system
-reset.  In this case the non-initial extensions will be not called.
-The fatal extensions are called with three parameters:
-- the fatal source,
-- a legacy parameter which is always false, and
-- an error code with a fatal source dependent content.
-Once all fatal extensions executed, the error information will be stored to
-:c:data:`_Internal_errors_What_happened` and the system state is set to
-:c:macro:`SYSTEM_STATE_TERMINATED`.
-The final step is to call the CPU port specific :c:func:`_CPU_Fatal_halt()`.
-Directives
-This section details the fatal error manager's directives.  A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
-.. raw:: latex
-   \clearpage
-.. index:: announce fatal error
-.. index:: fatal error, announce
-.. index:: rtems_fatal
-.. _rtems_fatal:
-FATAL - Invoke the fatal error handler
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_fatal(
-          rtems_fatal_source fatal_source,
-          rtems_fatal_code   error_code
-        ) RTEMS_NO_RETURN;
-DIRECTIVE STATUS CODES:
-    NONE - This function will not return to the caller.
-DESCRIPTION:
-    This directive terminates the system.
-NOTE:
-    Registered :c:func:`atexit()` or :c:func:`on_exit()` handlers are not
-    called.  Use :c:func:`exit()` in case these handlers should be invoked.
-.. raw:: latex
-   \clearpage
-.. index:: panic
-.. index:: rtems_panic
-.. _rtems_panic:
-PANIC - Print a message and invoke the fatal error handler
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_panic(
-          const char *fmt,
-        ) RTEMS_NO_RETURN RTEMS_PRINTFLIKE( 1, 2 );
-DESCRIPTION:
-    This directive prints a message via :c:func:`printk` specified by the
-    format and optional parameters and then terminates the system with the
-    :c:macro:`RTEMS_FATAL_SOURCE_PANIC` fatal source.  The fatal code is set to
-    the format string address.
-NOTE:
-.. raw:: latex
-   \clearpage
-.. index:: shutdown RTEMS
-.. index:: rtems_shutdown_executive
-.. _rtems_shutdown_executive:
-SHUTDOWN_EXECUTIVE - Shutdown RTEMS
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_shutdown_executive(
-            uint32_t result
-DESCRIPTION:
-    This directive is called when the application wishes to shutdown RTEMS.
-    The system is terminated with a fatal source of ``RTEMS_FATAL_SOURCE_EXIT``
-    and the specified ``result`` code.
-NOTES:
-    This directive *must* be the last RTEMS directive invoked by an application
-    and it *does not return* to the caller.
-    This directive may be called any time.
-.. raw:: latex
-   \clearpage
-.. index:: exception frame
-.. index:: rtems_exception_frame_print
-.. _rtems_exception_frame_print:
-EXCEPTION_FRAME_PRINT - Prints the exception frame
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_exception_frame_print(
-            const rtems_exception_frame *frame
-    NONE
-DESCRIPTION:
-    Prints the exception frame via ``printk()``.
-.. raw:: latex
-   \clearpage
-.. index:: rtems_fatal_source_text
-.. _rtems_fatal_source_text:
-FATAL_SOURCE_TEXT - Returns a text for a fatal source
-CALLING SEQUENCE:
-    .. code-block:: c
-        const char *rtems_fatal_source_text(
-            rtems_fatal_source source
-    The fatal source text or "?" in case the passed fatal source is invalid.
-DESCRIPTION:
-    Returns a text for a fatal source.  The text for fatal source is the
-    enumerator constant.
-.. raw:: latex
-   \clearpage
-.. index:: rtems_internal_error_text
-.. _rtems_internal_error_text:
-INTERNAL_ERROR_TEXT - Returns a text for an internal error code
-CALLING SEQUENCE:
-    .. code-block:: c
-        const char *rtems_internal_error_text(
-    The error code text or "?" in case the passed error code is invalid.
-DESCRIPTION:
-    Returns a text for an internal error code.  The text for each internal
-    error code is the enumerator constant.
-.. raw:: latex
-   \clearpage
-.. index:: rtems_fatal_error_occurred
-.. _rtems_fatal_error_occurred:
-FATAL_ERROR_OCCURRED - Invoke the fatal error handler (deprecated)
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_fatal_error_occurred(
-            uint32_t  the_error
-DESCRIPTION:
-    This directive processes fatal errors.  If the FATAL error extension is
-    defined in the configuration table, then the user-defined error extension
-    is called.  If configured and the provided FATAL error extension returns,
-    then the RTEMS default error handler is invoked.  This directive can be
-    invoked by RTEMS or by the user's application code including initialization
-    tasks, other tasks, and ISRs.
-NOTES:
-    This directive is deprecated and should not be used in new code.
-    This directive supports local operations only.
-    Unless the user-defined error extension takes special actions such as
-    restarting the calling task, this directive WILL NOT RETURN to the caller.
-    The user-defined extension for this directive may wish to initiate a global
-    shutdown.
diff --git a/c-user/fatal-error/directives.rst b/c-user/fatal-error/directives.rst
new file mode 100644
index 0000000..2d9a476
--- /dev/null
+++ b/c-user/fatal-error/directives.rst
@@ -0,0 +1,226 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Directives
+This section details the fatal error manager's directives.  A subsection is
+dedicated to each of this manager's directives and describes the calling
+sequence, related constants, usage, and status codes.
+.. raw:: latex
+   \clearpage
+.. index:: announce fatal error
+.. index:: fatal error, announce
+.. index:: rtems_fatal
+.. _rtems_fatal:
+FATAL - Invoke the fatal error handler
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_fatal(
+          rtems_fatal_source fatal_source,
+          rtems_fatal_code   error_code
+        ) RTEMS_NO_RETURN;
+DIRECTIVE STATUS CODES:
+    NONE - This function will not return to the caller.
+DESCRIPTION:
+    This directive terminates the system.
+NOTE:
+    Registered :c:func:`atexit()` or :c:func:`on_exit()` handlers are not
+    called.  Use :c:func:`exit()` in case these handlers should be invoked.
+.. raw:: latex
+   \clearpage
+.. index:: panic
+.. index:: rtems_panic
+.. _rtems_panic:
+PANIC - Print a message and invoke the fatal error handler
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_panic(
+          const char *fmt,
+        ) RTEMS_NO_RETURN RTEMS_PRINTFLIKE( 1, 2 );
+DESCRIPTION:
+    This directive prints a message via :c:func:`printk` specified by the
+    format and optional parameters and then terminates the system with the
+    :c:macro:`RTEMS_FATAL_SOURCE_PANIC` fatal source.  The fatal code is set to
+    the format string address.
+NOTE:
+.. raw:: latex
+   \clearpage
+.. index:: shutdown RTEMS
+.. index:: rtems_shutdown_executive
+.. _rtems_shutdown_executive:
+SHUTDOWN_EXECUTIVE - Shutdown RTEMS
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_shutdown_executive(
+            uint32_t result
+DESCRIPTION:
+    This directive is called when the application wishes to shutdown RTEMS.
+    The system is terminated with a fatal source of ``RTEMS_FATAL_SOURCE_EXIT``
+    and the specified ``result`` code.
+NOTES:
+    This directive *must* be the last RTEMS directive invoked by an application
+    and it *does not return* to the caller.
+    This directive may be called any time.
+.. raw:: latex
+   \clearpage
+.. index:: exception frame
+.. index:: rtems_exception_frame_print
+.. _rtems_exception_frame_print:
+EXCEPTION_FRAME_PRINT - Prints the exception frame
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_exception_frame_print(
+            const rtems_exception_frame *frame
+    NONE
+DESCRIPTION:
+    Prints the exception frame via ``printk()``.
+.. raw:: latex
+   \clearpage
+.. index:: rtems_fatal_source_text
+.. _rtems_fatal_source_text:
+FATAL_SOURCE_TEXT - Returns a text for a fatal source
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_fatal_source_text(
+            rtems_fatal_source source
+    The fatal source text or "?" in case the passed fatal source is invalid.
+DESCRIPTION:
+    Returns a text for a fatal source.  The text for fatal source is the
+    enumerator constant.
+.. raw:: latex
+   \clearpage
+.. index:: rtems_internal_error_text
+.. _rtems_internal_error_text:
+INTERNAL_ERROR_TEXT - Returns a text for an internal error code
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_internal_error_text(
+    The error code text or "?" in case the passed error code is invalid.
+DESCRIPTION:
+    Returns a text for an internal error code.  The text for each internal
+    error code is the enumerator constant.
+.. raw:: latex
+   \clearpage
+.. index:: rtems_fatal_error_occurred
+.. _rtems_fatal_error_occurred:
+FATAL_ERROR_OCCURRED - Invoke the fatal error handler (deprecated)
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_fatal_error_occurred(
+            uint32_t  the_error
+DESCRIPTION:
+    This directive processes fatal errors.  If the FATAL error extension is
+    defined in the configuration table, then the user-defined error extension
+    is called.  If configured and the provided FATAL error extension returns,
+    then the RTEMS default error handler is invoked.  This directive can be
+    invoked by RTEMS or by the user's application code including initialization
+    tasks, other tasks, and ISRs.
+NOTES:
+    This directive is deprecated and should not be used in new code.
+    This directive supports local operations only.
+    Unless the user-defined error extension takes special actions such as
+    restarting the calling task, this directive WILL NOT RETURN to the caller.
+    The user-defined extension for this directive may wish to initiate a global
+    shutdown.
diff --git a/c-user/fatal-error/index.rst b/c-user/fatal-error/index.rst
index 0000000..89cbe30
--- /dev/null
+++ b/c-user/fatal-error/index.rst
@@ -0,0 +1,17 @@
+.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: fatal errors
+.. _RTEMSAPIClassicFatal:
+Fatal Error Manager
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/fatal-error/introduction.rst b/c-user/fatal-error/introduction.rst
index 0000000..d862d4e
--- /dev/null
+++ b/c-user/fatal-error/introduction.rst
@@ -0,0 +1,25 @@
+Introduction
+The fatal error manager processes all fatal or irrecoverable errors and other
+sources of system termination (for example after :c:func:`exit()`).  Fatal
+errors are identified by the (fatal source, error code) pair.  The directives
+provided by the fatal error manager are:
+- :ref:`rtems_fatal`
+- :ref:`rtems_panic`
+- :ref:`rtems_shutdown_executive`
+- :ref:`rtems_exception_frame_print`
+- :ref:`rtems_fatal_source_text`
+- :ref:`rtems_internal_error_text`
+- :ref:`rtems_fatal_error_occurred`
diff --git a/c-user/fatal-error/operations.rst b/c-user/fatal-error/operations.rst
index 0000000..77753d6
--- /dev/null
+++ b/c-user/fatal-error/operations.rst
@@ -0,0 +1,51 @@
+Operations
+.. index:: _Terminate
+.. _Terminate:
+Announcing a Fatal Error
+The :c:func:`_Terminate()` internal error handler is invoked when the
+application or the executive itself determines that a fatal error has occurred
+or a final system state is reached (for example after :c:func:`rtems_fatal()`
+or :c:func:`exit()`).
+The first action of the internal error handler is to call the fatal extension of
+the user extensions.  For the initial extensions the following conditions are
+required
+- a valid stack pointer and enough stack space,
+- a valid code memory, and
+- valid read-only data.
+For the initial extensions the read-write data (including .bss segment) is not
+required on single processor configurations.  In SMP configurations, however,
+the read-write data must be initialized since this function must determine the
+state of the other processors and request them to shut-down if necessary.
+Non-initial extensions require in addition valid read-write data.  The board
+support package (BSP) may install an initial extension that performs a system
+reset.  In this case the non-initial extensions will be not called.
+The fatal extensions are called with three parameters:
+- the fatal source,
+- a legacy parameter which is always false, and
+- an error code with a fatal source dependent content.
+Once all fatal extensions executed, the error information will be stored to
+:c:data:`_Internal_errors_What_happened` and the system state is set to
+:c:macro:`SYSTEM_STATE_TERMINATED`.
+The final step is to call the CPU port specific :c:func:`_CPU_Fatal_halt()`.
diff --git a/c-user/index.rst b/c-user/index.rst
index 0a05c75..267d56c 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -44,7 +44,7 @@ RTEMS Classic API Guide (|version|).
 	region/index
 	dual-ported-memory/index
 	io/index
-	fatal_error
+	fatal-error/index
 	board_support_packages
 	user-extensions/index
 	config/index
diff --git a/c-user/initialization/introduction.rst b/c-user/initialization/introduction.rst
index ae14fb0..88805f2 100644
--- a/c-user/initialization/introduction.rst
+++ b/c-user/initialization/introduction.rst
@@ -7,7 +7,7 @@ Introduction
 The Initialization Manager is responsible for initializing the Board Support
 Package, RTEMS, device drivers, the root filesystem and the application.  The
-:ref:`Fatal Error Manager <fatal_error_manager>` is responsible for the system
+:ref:`RTEMSAPIClassicFatal` is responsible for the system
 shutdown.
 The Initialization Manager provides only one directive:
2.26.2
