[PATCH 3/8] c-user: Split up multiprocessing manager
Wed Apr 21 13:50:01 UTC 2021
This makes it easier to automatically generate parts of the module
documentation in the future.
Update #3993.
 c-user/index.rst                              |  2 +-
 .../background.rst}                           | 89 -------------------
 c-user/multiprocessing/directives.rst         | 44 +++++++++
 c-user/multiprocessing/index.rst              | 17 ++++
 c-user/multiprocessing/introduction.rst       | 35 ++++++++
 c-user/multiprocessing/operations.rst         | 13 +++
 6 files changed, 110 insertions(+), 90 deletions(-)
 rename c-user/{multiprocessing.rst => multiprocessing/background.rst} (84%)
 create mode 100644 c-user/multiprocessing/directives.rst
 create mode 100644 c-user/multiprocessing/index.rst
 create mode 100644 c-user/multiprocessing/introduction.rst
 create mode 100644 c-user/multiprocessing/operations.rst
diff --git a/c-user/index.rst b/c-user/index.rst
index 267d56c..5cd87af 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -49,7 +49,7 @@ RTEMS Classic API Guide (|version|).
 	user-extensions/index
 	config/index
 	self_contained_objects
-	multiprocessing
+	multiprocessing/index
 	symmetric_multiprocessing_services
 	pci_library
 	stack_bounds_checker
diff --git a/c-user/multiprocessing.rst b/c-user/multiprocessing/background.rst
similarity index 84%
rename from c-user/multiprocessing.rst
rename to c-user/multiprocessing/background.rst
index f207106..2aaae6e 100644
--- a/c-user/multiprocessing.rst
+++ b/c-user/multiprocessing/background.rst
@@ -2,44 +2,6 @@
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. index:: multiprocessing
-Multiprocessing Manager
-Introduction
-In multiprocessor real-time systems, new requirements, such as sharing data and
-global resources between processors, are introduced.  This requires an
-efficient and reliable communications vehicle which allows all processors to
-communicate with each other as necessary.  In addition, the ramifications of
-multiple processors affect each and every characteristic of a real-time system,
-almost always making them more complicated.
-RTEMS addresses these issues by providing simple and flexible real-time
-multiprocessing capabilities.  The executive easily lends itself to both
-tightly-coupled and loosely-coupled configurations of the target system
-hardware.  In addition, RTEMS supports systems composed of both homogeneous and
-heterogeneous mixtures of processors and target boards.
-A major design goal of the RTEMS executive was to transcend the physical
-boundaries of the target hardware configuration.  This goal is achieved by
-presenting the application software with a logical view of the target system
-where the boundaries between processor nodes are transparent.  As a result, the
-application developer may designate objects such as tasks, queues, events,
-signals, semaphores, and memory blocks as global objects.  These global objects
-may then be accessed by any task regardless of the physical location of the
-object and the accessing task.  RTEMS automatically determines that the object
-being accessed resides on another processor and performs the actions required
-to access the desired object.  Simply stated, RTEMS allows the entire system,
-both hardware and software, to be viewed logically as a single system.
-The directives provided by the  Manager are:
-- rtems_multiprocessing_announce_ - A multiprocessing communications packet has
-  arrived
 .. index:: multiprocessing topologies
 Background
@@ -455,54 +417,3 @@ of the following:
 - RTEMS makes no assumptions regarding the application data component of the
   packet.
-Operations
-Announcing a Packet
-The ``rtems_multiprocessing_announce`` directive is called by the MPCI layer to
-inform RTEMS that a packet has arrived from another node.  This directive can
-be called from an interrupt service routine or from within a polling routine.
-Directives
-This section details the additional directives required to support RTEMS in a
-multiprocessor configuration.  A subsection is dedicated to each of this
-manager's directives and describes the calling sequence, related constants,
-usage, and status codes.
-.. raw:: latex
-   \clearpage
-.. index:: announce arrival of package
-.. index:: rtems_multiprocessing_announce
-.. _rtems_multiprocessing_announce:
-MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet
-CALLING SEQUENCE:
-    .. code-block:: c
-        void rtems_multiprocessing_announce( void );
-DIRECTIVE STATUS CODES:
-    NONE
-DESCRIPTION:
-    This directive informs RTEMS that a multiprocessing communications packet
-    has arrived from another node.  This directive is called by the
-    user-provided MPCI, and is only used in multiprocessor configurations.
-NOTES:
-    This directive is typically called from an ISR.
-    This directive will almost certainly cause the calling task to be
-    preempted.
-    This directive does not generate activity on remote nodes.
diff --git a/c-user/multiprocessing/directives.rst b/c-user/multiprocessing/directives.rst
new file mode 100644
index 0000000..afa3244
--- /dev/null
+++ b/c-user/multiprocessing/directives.rst
@@ -0,0 +1,44 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Directives
+This section details the additional directives required to support RTEMS in a
+multiprocessor configuration.  A subsection is dedicated to each of this
+manager's directives and describes the calling sequence, related constants,
+usage, and status codes.
+.. raw:: latex
+   \clearpage
+.. index:: announce arrival of package
+.. index:: rtems_multiprocessing_announce
+.. _rtems_multiprocessing_announce:
+MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_multiprocessing_announce( void );
+DIRECTIVE STATUS CODES:
+    NONE
+DESCRIPTION:
+    This directive informs RTEMS that a multiprocessing communications packet
+    has arrived from another node.  This directive is called by the
+    user-provided MPCI, and is only used in multiprocessor configurations.
+NOTES:
+    This directive is typically called from an ISR.
+    This directive will almost certainly cause the calling task to be
+    preempted.
+    This directive does not generate activity on remote nodes.
diff --git a/c-user/multiprocessing/index.rst b/c-user/multiprocessing/index.rst
index 0000000..4ec4433
--- /dev/null
+++ b/c-user/multiprocessing/index.rst
@@ -0,0 +1,17 @@
+.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: multiprocessing
+.. _RTEMSAPIClassicMP:
+Multiprocessing Manager
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/multiprocessing/introduction.rst b/c-user/multiprocessing/introduction.rst
index 0000000..3a5edd5
--- /dev/null
+++ b/c-user/multiprocessing/introduction.rst
@@ -0,0 +1,35 @@
+Introduction
+In multiprocessor real-time systems, new requirements, such as sharing data and
+global resources between processors, are introduced.  This requires an
+efficient and reliable communications vehicle which allows all processors to
+communicate with each other as necessary.  In addition, the ramifications of
+multiple processors affect each and every characteristic of a real-time system,
+almost always making them more complicated.
+RTEMS addresses these issues by providing simple and flexible real-time
+multiprocessing capabilities.  The executive easily lends itself to both
+tightly-coupled and loosely-coupled configurations of the target system
+hardware.  In addition, RTEMS supports systems composed of both homogeneous and
+heterogeneous mixtures of processors and target boards.
+A major design goal of the RTEMS executive was to transcend the physical
+boundaries of the target hardware configuration.  This goal is achieved by
+presenting the application software with a logical view of the target system
+where the boundaries between processor nodes are transparent.  As a result, the
+application developer may designate objects such as tasks, queues, events,
+signals, semaphores, and memory blocks as global objects.  These global objects
+may then be accessed by any task regardless of the physical location of the
+object and the accessing task.  RTEMS automatically determines that the object
+being accessed resides on another processor and performs the actions required
+to access the desired object.  Simply stated, RTEMS allows the entire system,
+both hardware and software, to be viewed logically as a single system.
+The directives provided by the  Manager are:
+- :ref:`rtems_multiprocessing_announce`
diff --git a/c-user/multiprocessing/operations.rst b/c-user/multiprocessing/operations.rst
index 0000000..08dcded
--- /dev/null
+++ b/c-user/multiprocessing/operations.rst
@@ -0,0 +1,13 @@
+Operations
+Announcing a Packet
+The ``rtems_multiprocessing_announce`` directive is called by the MPCI layer to
+inform RTEMS that a packet has arrived from another node.  This directive can
+be called from an interrupt service routine or from within a polling routine.
2.26.2
