STM32H7 UART pins Update
Robin Müller
robin.mueller.m at gmail.com
Thu Apr 22 13:24:39 UTC 2021
Small corrections: I was always referring to GPIOB PIN9 and PIN10 of course.
Kind Regards
Robin
On Thu, 22 Apr 2021 at 15:20, Robin Müller <robin.mueller.m at gmail.com>
wrote:
> Hi Sebastian
> You recently updated the UART pins configuration, allowing different
> variants.
> I recently checked the CubeH7 library about pin differences between the
> NUCLEO and the STM32H7 after finding out about the pin differences for the
> Ethernet module and I found out some weird things. I checked the datasheet
> which specifies that GPIOD PIN8 and PIN9 are the UART3 pins used for the
> console / print output.
> So basically, the default implementation is now okay for the Nucleo as
> well. I checked bspopts.h in the RTEMS tools installation path, and the
> default values GPIOD and PIN8 and PIN9 were specified here. So basically,
> the build variant specifications GPIOB PIN 8 and PIN 9 are not used.
> This was because of stray default-by-variant: [] in the respective BSP
> files. I then tested GPIOB PIN8 and PIN 9 by setting them in default: and
> those don't work as expected.
> If GPIOD PIN 8 and PIN 9 work for the board variant you used then these
> option specifications are obsolete now and that pin definition works for
> the NUCLEO and the board you used. The former implementation used GPIOB PIN
> 9 and PIN 10 (
> https://git.rtems.org/rtems/commit/bsps/arm/stm32h7/console/console-usart3-cfg.c?id=6600585fc8e5fa299bf1ca1e0856d44b23c195cf)
> which is the reason they were not working for the NUCLEO variant.
> Kind Regards
> Robin
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/64def5ab/attachment.html>
