[PATCH v2] sb: Merge mailer changes from rtems-tools
Thu Apr 22 13:50:13 UTC 2021
On Thu, Apr 22, 2021 at 7:18 AM Alex White <alex.white at oarcorp.com> wrote:
> This adds the improved mailer.py script from rtems-tools.
> Closes #4388
>  source-builder/sb/mailer.py     | 192 ++++++++++++++++++++++++++------
>  source-builder/sb/options.py    |  26 ++++-
>  source-builder/sb/setbuilder.py |   2 +
>  3 files changed, 187 insertions(+), 33 deletions(-)
> diff --git a/source-builder/sb/mailer.py b/source-builder/sb/mailer.py
> index ff25df5..ee5bf07 100644
> --- a/source-builder/sb/mailer.py
> +++ b/source-builder/sb/mailer.py
> @@ -1,21 +1,32 @@
>  # RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2013 Chris Johns (chrisj at rtems.org)
> +# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
OAR copyright?
>  # All rights reserved.
>  # This file is part of the RTEMS Tools package in 'rtems-tools'.
> -# Permission to use, copy, modify, and/or distribute this software for any
> -# purpose with or without fee is hereby granted, provided that the above
> -# copyright notice and this permission notice appear in all copies.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> -# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
> -# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
> -# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
> -# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
> -# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
> -# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
> -# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
>  # Manage emailing results or reports.
> @@ -28,18 +39,71 @@ import smtplib
>  import socket
>  from . import error
> +from . import execute
>  from . import options
>  from . import path
> +_options = {
> +    '--mail'         : 'Send email report or results.',
> +    '--use-gitconfig': 'Use mail configuration from git config.',
> +    '--mail-to'      : 'Email address to send the email to.',
> +    '--mail-from'    : 'Email address the report is from.',
> +    '--smtp-host'    : 'SMTP host to send via.',
> +    '--smtp-port'    : 'SMTP port to send via.',
> +    '--smtp-user'    : 'User for SMTP authentication.',
> +    '--smtp-password': 'Password for SMTP authentication.'
>  def append_options(opts):
> -    opts['--mail'] = 'Send email report or results.'
> -    opts['--smtp-host'] = 'SMTP host to send via.'
> -    opts['--mail-to'] = 'Email address to send the email too.'
> -    opts['--mail-from'] = 'Email address the report is from.'
> +    for o in _options:
> +        opts[o] = _options[o]
> +def add_arguments(argsp):
> +    argsp.add_argument('--mail', help = _options['--mail'], action = 'store_true')
> +    argsp.add_argument('--use-gitconfig', help = _options['--use-gitconfig'], action = 'store_true')
> +    for o in list(_options)[1:]:
> +        argsp.add_argument(o, help = _options[o], type = str)
>  class mail:
>      def __init__(self, opts):
>          self.opts = opts
> +        self.gitconfig_lines = None
> +        if opts.find_arg('--use-gitconfig') is not None:
> +            # Read the output of `git config --list` instead of reading the
> +            # .gitconfig file directly because Python 2 ConfigParser does not
> +            # accept tabs at the beginning of lines.
> +            e = execute.capture_execution()
> +            exit_code, proc, output = e.open('git config --list', shell=True)
> +            if exit_code == 0:
> +                self.gitconfig_lines = output.split(os.linesep)
> +    def _args_are_macros(self):
> +        return isinstance(self.opts, options.command_line)
> +    def _get_arg(self, arg):
> +        if self._args_are_macros():
> +            value = self.opts.find_arg(arg)
> +            if value is not None:
> +                value = self.opts.find_arg(arg)[1]
> +        else:
> +            if arg.startswith('--'):
> +                arg = arg[2:]
> +            arg = arg.replace('-', '_')
> +            if arg in vars(self.opts):
> +                value = vars(self.opts)[arg]
> +            else:
> +                value = None
> +        return value
> +    def _get_from_gitconfig(self, variable_name):
> +        if self.gitconfig_lines is None:
> +            return None
> +        for line in self.gitconfig_lines:
> +            if line.startswith(variable_name):
> +                ls = line.split('=')
> +                if len(ls) >= 2:
> +                    return ls[1]
>      def from_address(self):
> @@ -52,9 +116,15 @@ class mail:
>                  l = l[:l.index('\n')]
>              return l.strip()
> -        addr = self.opts.get_arg('--mail-from')
> +        addr = self._get_arg('--mail-from')
>          if addr is not None:
> -            return addr[1]
> +            return addr
> +        addr = self._get_from_gitconfig('user.email')
> +        if addr is not None:
> +            name = self._get_from_gitconfig('user.name')
> +            if name is not None:
> +                addr = '%s <%s>' % (name, addr)
> +            return addr
>          mailrc = None
>          if 'MAILRC' in os.environ:
>              mailrc = os.environ['MAILRC']
> @@ -63,9 +133,8 @@ class mail:
>          if mailrc is not None and path.exists(mailrc):
>              # set from="Joe Blow <joe at blow.org>"
>              try:
> -                mrc = open(mailrc, 'r')
> -                lines = mrc.readlines()
> -                mrc.close()
> +                with open(mailrc, 'r') as mrc:
> +                    lines = mrc.readlines()
>              except IOError as err:
>                  raise error.general('error reading: %s' % (mailrc))
>              for l in lines:
> @@ -76,40 +145,99 @@ class mail:
>                          addr = fa[fa.index('=') + 1:].replace('"', ' ').strip()
>                  return addr
> -        addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> +            addr = self.opts.defaults.get_value('%{_sbgit_mail}')
> +        else:
> +            raise error.general('no valid from address for mail')
>          return addr
>      def smtp_host(self):
> -        host = self.opts.get_arg('--smtp-host')
> +        host = self._get_arg('--smtp-host')
>          if host is not None:
> -            return host[1]
> -        host = self.opts.defaults.get_value('%{_mail_smtp_host}')
> +            return host
> +        host = self._get_from_gitconfig('sendemail.smtpserver')
> +        if host is not None:
> +            return host
> +            host = self.opts.defaults.get_value('%{_mail_smtp_host}')
>              return host
>          return 'localhost'
> +    def smtp_port(self):
> +        port = self._get_arg('--smtp-port')
> +        if port is not None:
> +            return port
> +        port = self._get_from_gitconfig('sendemail.smtpserverport')
> +            return port
> +            port = self.opts.defaults.get_value('%{_mail_smtp_port}')
> +        return port
> +    def smtp_user(self):
> +        user = self._get_arg('--smtp-user')
> +        if user is not None:
> +            return user
> +        user = self._get_from_gitconfig('sendemail.smtpuser')
> +        return user
> +    def smtp_password(self):
> +        password = self._get_arg('--smtp-password')
> +        if password is not None:
> +            return password
> +        password = self._get_from_gitconfig('sendemail.smtppass')
> +        return password
>      def send(self, to_addr, subject, body):
>          from_addr = self.from_address()
>          msg = "From: %s\r\nTo: %s\r\nSubject: %s\r\n\r\n" % \
>              (from_addr, to_addr, subject) + body
> -        if type(to_addr) is str:
> -            to_addr = to_addr.split(',')
> -        if type(to_addr) is not list:
> -            raise error.general('invalid to_addr type')
> +        port = self.smtp_port()
>          try:
> -            s = smtplib.SMTP(self.smtp_host())
> -            s.sendmail(from_addr, to_addr, msg)
> +            s = smtplib.SMTP(self.smtp_host(), port, timeout=10)
> +            password = self.smtp_password()
> +            # If a password is provided, assume that authentication is required.
> +                user = self.smtp_user()
> +                if user is None:
> +                    user = from_addr
> +                s.starttls()
> +                s.login(user, password)
> +            s.sendmail(from_addr, [to_addr], msg)
>          except smtplib.SMTPException as se:
>              raise error.general('sending mail: %s' % (str(se)))
>          except socket.error as se:
> +    def send_file_as_body(self, to_addr, subject, name, intro = None):
> +        try:
> +            with open(name, 'r') as f:
> +                body = f.readlines()
> +        except IOError as err:
> +            raise error.general('error reading mail body: %s' % (name))
> +        if intro is not None:
> +            body = intro + body
> +        self.send(to_addr, from_addr, body)
>  if __name__ == '__main__':
>      import sys
> +    from . import macros
>      optargs = {}
> +    rtdir = 'source-builder'
> +    defaults = '%s/defaults.mc' % (rtdir)
>      append_options(optargs)
> -    opts = options.load(sys.argv, optargs = optargs, defaults = 'defaults.mc')
> +    opts = options.command_line(base_path = '.',
> +                                argv = sys.argv,
> +                                optargs = optargs,
> +                                defaults = macros.macros(name = defaults, rtdir = rtdir),
> +                                command_path = '.')
> +    options.load(opts)
>      m = mail(opts)
>      print('From: %s' % (m.from_address()))
>      print('SMTP Host: %s' % (m.smtp_host()))
> -    m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> +    if '--mail' in sys.argv:
> +        m.send(m.from_address(), 'Test mailer.py', 'This is a test')
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index d6bffd0..a0f196b 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -517,6 +517,15 @@ class command_line:
>              return None
>          return self.parse_args(arg)
> +    def find_arg(self, arg):
> +        if self.optargs is None or arg not in self.optargs:
> +            raise error.internal('bad arg: %s' % (arg))
> +        for a in self.args:
> +            sa = a.split('=')
> +            if sa[0].startswith(arg):
> +                return sa
> +        return None
>      def with_arg(self, label, default = 'not-found'):
>          # the default if there is no option for without.
>          result = default
> @@ -582,7 +591,22 @@ class command_line:
>          self.opts['no-install'] = '1'
>      def info(self):
> -        s = ' Command Line: %s%s' % (' '.join(self.argv), os.linesep)
> +        # Filter potentially sensitive mail options out.
> +        filtered_args = [
> +            arg for arg in self.argv
> +            if all(
> +                smtp_opt not in arg
> +                for smtp_opt in [
> +                    '--smtp-host',
> +                    '--mail-to',
> +                    '--mail-from',
> +                    '--smtp-user',
> +                    '--smtp-password',
> +                    '--smtp-port'
> +        s = ' Command Line: %s%s' % (' '.join(filtered_args), os.linesep)
>          s += ' Python: %s' % (sys.version.replace('\n', ''))
>          return s
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index b0e2b23..c8c8fee 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> @@ -695,6 +695,8 @@ def run():
>                       'log'    : '',
>                       'reports': [],
>                       'failure': None }
> +            # Request this now to generate any errors.
> +            smtp_host = mail['mail'].smtp_host()
>              to_addr = opts.get_arg('--mail-to')
>              if to_addr is not None:
>                  mail['to'] = to_addr[1]
> 2.27.0
> devel mailing list
> devel at rtems.org
