[PATCH] Updated tick implementation for HAL_GetTick
Thu Apr 22 14:02:30 UTC 2021
On 22/04/2021 14:17, Robin Müller wrote:
> It worked for me. Can you specify that? The overflow check would have
> to be implemented by an upper layer, right?
> I can adapt my former patch using the tick solution to do the
> multiplication first if this is better.
If you call HAL_GetTick() when the clock tick is 0xffffabcd and then
0x123 and you calculate the difference of the results, the value should
be all right. I am not sure if this is the case if you calculate it by
rtems_clock_get_ticks_since_boot() * 1000) /
rtems_clock_get_ticks_per_second()
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
