[PATCH] c-user: fix broken definition in rate-monotonic background.
Gedare Bloom
gedare at rtems.org
Thu Apr 22 15:10:45 UTC 2021
c-user/rate-monotonic/background.rst | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/c-user/rate-monotonic/background.rst b/c-user/rate-monotonic/background.rst
index 9ca7dff..c81af4e 100644
--- a/c-user/rate-monotonic/background.rst
+++ b/c-user/rate-monotonic/background.rst
@@ -112,7 +112,9 @@ less than its period. For example, a periodic task's requirements may state
that it should execute for 10 milliseconds every 100 milliseconds. Although
the execution time may be the average, worst, or best case, the worst-case
execution time is more appropriate for use when analyzing system behavior under
-transient overload conditions... index:: aperiodic task, definition
+transient overload conditions.
+.. index:: aperiodic task, definition
In contrast, an aperiodic task executes at irregular intervals and has only a
soft deadline. In other words, the deadlines for aperiodic tasks are not
2.25.1
