[PATCH] c-user: fix broken definition in rate-monotonic background.
Joel Sherrill
joel at rtems.org
Thu Apr 22 15:12:40 UTC 2021
If that's just a formatting error fix, looks good. Push it.
If it's more, poke me.
On Thu, Apr 22, 2021, 10:10 AM Gedare Bloom <gedare at rtems.org> wrote:
> c-user/rate-monotonic/background.rst | 4 +++-
> 1 file changed, 3 insertions(+), 1 deletion(-)
> diff --git a/c-user/rate-monotonic/background.rst
> b/c-user/rate-monotonic/background.rst
> index 9ca7dff..c81af4e 100644
> --- a/c-user/rate-monotonic/background.rst
> +++ b/c-user/rate-monotonic/background.rst
> @@ -112,7 +112,9 @@ less than its period. For example, a periodic task's
> requirements may state
> that it should execute for 10 milliseconds every 100 milliseconds.
> Although
> the execution time may be the average, worst, or best case, the worst-case
> execution time is more appropriate for use when analyzing system behavior
> under
> -transient overload conditions... index:: aperiodic task, definition
> +transient overload conditions.
> +.. index:: aperiodic task, definition
> In contrast, an aperiodic task executes at irregular intervals and has
> only a
> soft deadline. In other words, the deadlines for aperiodic tasks are not
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/27004978/attachment.html>
