[PATCH] c-user: fix broken definition in rate-monotonic background.
Gedare Bloom
gedare at rtems.org
Thu Apr 22 15:21:14 UTC 2021
Just formatting, but Sebastian works in this area right now, so maybe
he can pluck it or ACK a push is ok.
I noticed it while reviewing his doc generation patches.
On Thu, Apr 22, 2021 at 9:12 AM Joel Sherrill <joel at rtems.org> wrote:
> If that's just a formatting error fix, looks good. Push it.
> If it's more, poke me.
> On Thu, Apr 22, 2021, 10:10 AM Gedare Bloom <gedare at rtems.org> wrote:
>> c-user/rate-monotonic/background.rst | 4 +++-
>> 1 file changed, 3 insertions(+), 1 deletion(-)
>> diff --git a/c-user/rate-monotonic/background.rst b/c-user/rate-monotonic/background.rst
>> index 9ca7dff..c81af4e 100644
>> --- a/c-user/rate-monotonic/background.rst
>> +++ b/c-user/rate-monotonic/background.rst
>> @@ -112,7 +112,9 @@ less than its period. For example, a periodic task's requirements may state
>> that it should execute for 10 milliseconds every 100 milliseconds. Although
>> the execution time may be the average, worst, or best case, the worst-case
>> execution time is more appropriate for use when analyzing system behavior under
>> -transient overload conditions... index:: aperiodic task, definition
>> +transient overload conditions.
>> +.. index:: aperiodic task, definition
>> In contrast, an aperiodic task executes at irregular intervals and has only a
>> soft deadline. In other words, the deadlines for aperiodic tasks are not
>> 2.25.1
>> devel mailing list
>> devel at rtems.org
