[PATCH] psx13: Reworked and relicensed
Ryan Long ryan.long at oarcorp.com
Thu Apr 22 15:44:42 UTC 2021
What other file?
Sent: Thursday, April 22, 2021 9:21 AM
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: Gedare Bloom <gedare at rtems.org>; Ryan Long <ryan.long at oarcorp.com>; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: [PATCH] psx13: Reworked and relicensed
While you are updating the license on the OAR authored code, you should pick up the other file in this directory.
On Thu, Apr 22, 2021, 9:09 AM Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
On 22/04/2021 15:44, Gedare Bloom wrote:
>> +  rv = close( fd1 );
>> +  rtems_test_assert( rv == 0 );
> Just curious, why be inconsistent how you check for the return from
> close? Above using != EOF, here using == 0. It doesn't matter greatly.
Different APIs are tested. One uses 0, the other uses EOF.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/4b1b0f84/attachment-0001.html>
