[PATCH] psx13: Reworked and relicensed
Thu Apr 22 15:47:56 UTC 2021
On Thu, Apr 22, 2021 at 9:44 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> What other file?
ls rtems/testsuites/psxtests/psx13
> From: Joel Sherrill <joel at rtems.org>
> Sent: Thursday, April 22, 2021 9:21 AM
> To: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Cc: Gedare Bloom <gedare at rtems.org>; Ryan Long <ryan.long at oarcorp.com>; rtems-devel at rtems.org <devel at rtems.org>
> Subject: Re: [PATCH] psx13: Reworked and relicensed
> While you are updating the license on the OAR authored code, you should pick up the other file in this directory.
> On Thu, Apr 22, 2021, 9:09 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 22/04/2021 15:44, Gedare Bloom wrote:
> >> +  rv = close( fd1 );
> >> +  rtems_test_assert( rv == 0 );
> > Just curious, why be inconsistent how you check for the return from
> > close? Above using != EOF, here using == 0. It doesn't matter greatly.
> Different APIs are tested. One uses 0, the other uses EOF.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
