[PATCH] psx13: Reworked and relicensed
Joel Sherrill
joel at rtems.org
Thu Apr 22 15:50:45 UTC 2021
https://git.rtems.org/rtems/tree/testsuites/psxtests/psx13/main.c
On Thu, Apr 22, 2021, 10:48 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 22, 2021 at 9:44 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> > What other file?
> ls rtems/testsuites/psxtests/psx13
> > From: Joel Sherrill <joel at rtems.org>
> > Sent: Thursday, April 22, 2021 9:21 AM
> > To: Sebastian Huber <sebastian.huber at embedded-brains.de>
> > Cc: Gedare Bloom <gedare at rtems.org>; Ryan Long <ryan.long at oarcorp.com>;
> rtems-devel at rtems.org <devel at rtems.org>
> > Subject: Re: [PATCH] psx13: Reworked and relicensed
> > While you are updating the license on the OAR authored code, you should
> pick up the other file in this directory.
> > On Thu, Apr 22, 2021, 9:09 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 22/04/2021 15:44, Gedare Bloom wrote:
> > >> + rv = close( fd1 );
> > >> + rtems_test_assert( rv == 0 );
> > > Just curious, why be inconsistent how you check for the return from
> > > close? Above using != EOF, here using == 0. It doesn't matter greatly.
> > Different APIs are tested. One uses 0, the other uses EOF.
> > embedded brains GmbH
> > Herr Sebastian HUBER
> > Dornierstr. 4
> > 82178 Puchheim
> > Germany
> > email: sebastian.huber at embedded-brains.de
> > phone: +49-89-18 94 741 - 16
> > fax: +49-89-18 94 741 - 08
> > Registergericht: Amtsgericht München
> > Registernummer: HRB 157899
> > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > Unsere Datenschutzerklärung finden Sie hier:
> > https://embedded-brains.de/datenschutzerklaerung/
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/7a198dd7/attachment.html>
