STM32H7 UART pins Update
Robin Müller
robin.mueller.m at gmail.com
Thu Apr 22 17:36:45 UTC 2021
I think the pins for the UART 3 still need to be adapted. Everything can be
simplified because the pins are the same after all with GPIOD PIN 8 and
PIN9 for both variants.
I sent a patch which configures the ETH correctly for the Nucleo BSP
variant.
Kind Regards
Robin
On Thu, 22 Apr 2021 at 19:04, Robin Müller <robin.mueller.m at gmail.com>
wrote:
> Thanks :-) I was able to omit the HAL_ETH_MspInit override in my lwIP code
> now.
> Kind Regards
> Robin
> On Thu, 22 Apr 2021 at 15:32, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Robin,
>> I hope it is now fixed. For the Ethernet pin customization, you can use
>> the same approach.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210422/fa5f971c/attachment-0001.html>
