[PATCH RTEMS v2 0/1] bsp/beagle: Refactored i2c driver and Updated
Niteesh G. S.
niteesh.gs at gmail.com
Fri Apr 23 01:37:44 UTC 2021
Hello Christian,
On Thu, Apr 22, 2021 at 10:24 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Niteesh,
> thanks for the reminder and the patches. I pushed them.
Thanks for pushing them
Thank you,
Niteesh.
> Best regards
> Christian
> On 22/04/2021 05:54, Niteesh G. S. wrote:
> > Hello Christian,
> > Reminder to push the patches.
> > Thanks,
> > Niteesh
> > On Sun, Apr 18, 2021 at 11:57 PM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> > Hello Niteesh,
> > looks good to me. I'll wait two or three days before pushing so that
> > others can review the libbsd patch too. Please ping me on Wednesday
> > if I
> > didn't push it by then.
> > Best regards
> > Christian
> > On 18/04/2021 17:19, Niteesh G. S. wrote:
> > > Hello Christian,
> > > On Sun, Apr 18, 2021 at 4:54 PM Christian Mauderer
> > <oss at c-mauderer.de <mailto:oss at c-mauderer.de>
> > > <mailto:oss at c-mauderer.de <mailto:oss at c-mauderer.de>>> wrote:
> > > Hello Niteesh,
> > > sorry for not taking a look earlier.
> > > No problem
> > > The patches seem OK for me. Just a tiny change request:
> > > I know that I suggested the "rtems,path" for the device tree.
> > When
> > > testing I noted that we have the rtems-i2c driver in libbsd
> > which is
> > > more or less just a compatibility layer between libbsd and
> > RTEMS. This
> > > driver uses "rtems,i2c-path" instead of "rtems,path". Maybe
> > you could
> > > add one of these two solutions:
> > > 1. Either change "rtems,path" to "rtems,i2c-path" in your
> driver.
> > > 2. Or add "rtems,path" as an additional possible path to
> > > "libbsd/rtemsbsd/sys/dev/iicbus/rtems-i2c.c". Basically that
> > would just
> > > mean that in the error case of the current OF_getprop_alloc
> > you just
> > > try
> > > the "rtems,path" before failing.
> > > I really like the short and universal name of "rtems,path" so
> > I would
> > > prefer the second solution. But I would be OK with the first
> > one too.
> > > I have sent a patch for your preferred solution.
> > > Patches that are pending are:
> > > 1) https://lists.rtems.org/pipermail/devel/2021-April/066458.html
> > <https://lists.rtems.org/pipermail/devel/2021-April/066458.html>
> > <https://lists.rtems.org/pipermail/devel/2021-April/066458.html>>
> > > 2) https://lists.rtems.org/pipermail/devel/2021-April/066460.html
> > <https://lists.rtems.org/pipermail/devel/2021-April/066460.html>
> > <https://lists.rtems.org/pipermail/devel/2021-April/066460.html>>
> > > 3) https://lists.rtems.org/pipermail/devel/2021-April/066629.html
> > <https://lists.rtems.org/pipermail/devel/2021-April/066629.html>
> > <https://lists.rtems.org/pipermail/devel/2021-April/066629.html>>
> > > Thanks,
> > > Niteesh.
> > > Best regards
> > > Christian
> > > On 18/04/2021 06:20, Niteesh G. S. wrote:
> > > > ping.
> > > > On Sun, Apr 11, 2021 at 12:45 AM G S Niteesh Babu
> > > <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>
> > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>
> > <mailto:niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>>>> wrote:
> > > > The following two patches update the Beagle BSP i2c
> > driver to use
> > > > device tree based initialization and the documentation
> > related to
> > > > it.
> > > > G S Niteesh Babu (1):
> > > > bsps/beagle: Refactored i2c driver
> > > > bsps/arm/beagle/i2c/bbb-i2c.c | 122
> > > > bsps/arm/beagle/include/bsp.h | 4 +
> > > > bsps/arm/beagle/include/bsp/i2c.h | 32 +-------
> > > > bsps/arm/beagle/start/bspstart.c | 51 +++++++++----
> > > > 4 files changed, 114 insertions(+), 95 deletions(-)
> > > > 2.17.1
> > > > _______________________________________________
> > > > devel mailing list
> > > > devel at rtems.org <mailto:devel at rtems.org>
> > <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> > > > http://lists.rtems.org/mailman/listinfo/devel
> > <http://lists.rtems.org/mailman/listinfo/devel>
> > <http://lists.rtems.org/mailman/listinfo/devel>>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210423/3e9b9913/attachment.html>
