RTEMS on PolarFire SoC ICICLE Kit FPGA
somesh deshmukh
someshdeshmukh07 at gmail.com
Fri Apr 23 03:52:29 UTC 2021
I was able to test the rtems hello-world example and ticker example on the
polarfire soc icicle kit.
A little background about Polarfire SoC ICICLE Kit.
The PolarFire SoC Icicle kit is a low-cost development platform that
enables the evaluation of the five-core Linux capable RISC-V microprocessor
subsystem. It includes
- SiFive E51 Monitor core (1 x RV64IMAC)
- SiFive U54 Application cores (4 x RV64GC)
More info is available at the link below:
https://www.microsemi.com/existing-parts/parts/152514
There were few changes I had to make in the rtems source code to make it
work, as mentioned below.
1. In the startup code the bsp_fdt_copy copies the device tree blob from
the address from #a1 register to the .rodata section. This is followed by a
memset operation for the bss section.
The problem was the call to a memset function was clearing the device tree
blob copied in the bsp_fdt_copy() operation.
To fix this I performed the memset first and then bsp_fdt_copy operation.
2. The riscv_console_probe() will try to read the console_node from the
device tree. The original code provided for ns16550 UART was not able to
read the console node from the device tree correctly.
To fix this I used the sifive code to read the console node. The sifive
code was limited to only sifive-uart.
3. RTEMS uses -O2 as default optimization settings. With these settings, we
were facing a trap while trying to perform the open call on the console
device after mounting the file system.
To fix this I changed the optimization to -O0 and it resolved the issue.
I need to debug this more to find the exact cause.
4. The default clock driver simply assumes that the code is running on
hart0. This was breaking the ticker example testing.
To fix this I updated the clock driver to read the hart ID and then
configure the
mtimecmp register accordingly.
Let me know if these changes are valid.
Regards,
Somesh
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210423/e89a30bf/attachment.html>
