RTEMS on PolarFire SoC ICICLE Kit FPGA
Karel Gardas
karel.gardas at centrum.cz
Fri Apr 23 09:11:11 UTC 2021
Hi Somesh,
your information are very interesting. Is it possible for your to send a
diff of your changes?
Thanks,
Karel
On 4/23/21 5:52 AM, somesh deshmukh wrote:
> I was able to test the rtems hello-world example and ticker example on
> the polarfire soc icicle kit.
> A little background about Polarfire SoC ICICLE Kit.
> The PolarFire SoC Icicle kit is a low-cost development platform that
> enables the evaluation of the five-core Linux capable RISC-V
> microprocessor subsystem. It includes
> * SiFive E51 Monitor core (1 x RV64IMAC)
> * SiFive U54 Application cores (4 x RV64GC)
> More info is available at the link below:
> https://www.microsemi.com/existing-parts/parts/152514
> <https://www.microsemi.com/existing-parts/parts/152514>
> There were few changes I had to make in the rtems source code to make it
> work, as mentioned below.
> 1. In the startup code the bsp_fdt_copy copies the device tree blob from
> the address from #a1 register to the .rodata section. This is followed
> by a memset operation for the bss section.
> The problem was the call to a memset function was clearing the device
> tree blob copied in the bsp_fdt_copy() operation.
> To fix this I performed the memset first and then bsp_fdt_copy operation.
> 2. The riscv_console_probe() will try to read the console_node from the
> device tree. The original code provided for ns16550 UART was not able to
> read the console node from the device tree correctly.
> To fix this I used the sifive code to read the console node. The sifive
> code was limited to only sifive-uart.
> 3. RTEMS uses -O2 as default optimization settings. With these settings,
> we were facing a trap while trying to perform the open call on the
> console device after mounting the file system.
> To fix this I changed the optimization to -O0 and it resolved the issue.
> I need to debug this more to find the exact cause.
> 4. The default clock driver simply assumes that the code is running on
> hart0. This was breaking the ticker example testing.
> To fix this I updated the clock driver to read the hart ID and then
> configure the
> mtimecmp register accordingly.
> Let me know if these changes are valid.
> Regards,
> Somesh
> devel mailing list
> devel at rtems.org
