RTEMS Bootstrap fails
Richi Dubey richidubey at gmail.com
Sun Apr 25 05:07:27 UTC 2021
It does. Thanks for your prompt response!
Also, how do I enable SMP tests and rtems-debug?
On Fri, Apr 23, 2021 at 9:03 PM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> Hi Richi,
> On Fri, Apr 23, 2021 at 9:22 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Hi,
> > I am building a new RTEMS from master source (to build the
> xilinx_zynqmp_lp64 bsp from the aarch64 arch), and these are the steps I
> followed:
> > mkdir -p $HOME/quick-start/src
> > cd $HOME/quick-start/src
> > git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> > git clone https://github.com/RTEMS/rtems.git
> > cd $HOME/quick-start/src/rsb/rtems
> > ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
> 6/rtems-aarch64
> >  export PATH=$HOME/quick-start/rtems/6/bin:"$PATH"
> > cd $HOME/quick-start/src/rtems
> > ./rtems-bootstrap
> > -And I get this error-:
> > 118/119: autoreconf: c/src/make/configure.ac
> > 119/119: autoreconf: cpukit/configure.ac
> > automake: error: cannot open < libnetworking/headers.am: No such file
> or directory
> > autoreconf: automake failed with exit status: 1
> > error: error: autoreconf: autoreconf -i --no-recursive
> > Bootstrap FAILED.
> Please try using waf.
> echo "[aarch64/xilinx_zynqmp_lp64]" > config.ini
> echo "BUILD_TESTS=True" >> config.ini
> ./waf configure
> ./waf
> ./waf install
> > Can someone please help me with this?
> I hope the above instructions will build it without issues.
> Best regards,
> Vijay
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210425/38247549/attachment.html>
