RTEMS Bootstrap fails
Vijay Kumar Banerjee
vijay at rtems.org
Sun Apr 25 05:10:10 UTC 2021
On Sat, Apr 24, 2021 at 11:08 PM Richi Dubey <richidubey at gmail.com> wrote:
> It does. Thanks for your prompt response!
> Also, how do I enable SMP tests and rtems-debug?
I think the options are these:
RTEMS_SMP = True
RTEMS_DEBUG = True
Add it to the config.ini file and configure it again before building.
> On Fri, Apr 23, 2021 at 9:03 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>> Hi Richi,
>> On Fri, Apr 23, 2021 at 9:22 AM Richi Dubey <richidubey at gmail.com> wrote:
>> > Hi,
>> > I am building a new RTEMS from master source (to build the xilinx_zynqmp_lp64 bsp from the aarch64 arch), and these are the steps I followed:
>> > mkdir -p $HOME/quick-start/src
>> > cd $HOME/quick-start/src
>> > git clone https://github.com/RTEMS/rtems-source-builder.git rsb
>> > git clone https://github.com/RTEMS/rtems.git
>> > cd $HOME/quick-start/src/rsb/rtems
>> > ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6 6/rtems-aarch64
>> > export PATH=$HOME/quick-start/rtems/6/bin:"$PATH"
>> > cd $HOME/quick-start/src/rtems
>> > ./rtems-bootstrap
>> > -And I get this error-:
>> > 118/119: autoreconf: c/src/make/configure.ac
>> > 119/119: autoreconf: cpukit/configure.ac
>> > automake: error: cannot open < libnetworking/headers.am: No such file or directory
>> > autoreconf: automake failed with exit status: 1
>> > error: error: autoreconf: autoreconf -i --no-recursive
>> > Bootstrap FAILED.
>> Please try using waf.
>> echo "[aarch64/xilinx_zynqmp_lp64]" > config.ini
>> echo "BUILD_TESTS=True" >> config.ini
>> ./waf configure
>> ./waf
>> ./waf install
>> > Can someone please help me with this?
>> I hope the above instructions will build it without issues.
>> Best regards,
>> Vijay
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
