RTEMS Bootstrap fails
Richi Dubey richidubey at gmail.com
Sun Apr 25 05:10:51 UTC 2021
Cool, Thanks!
On Sun, Apr 25, 2021 at 10:40 AM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> On Sat, Apr 24, 2021 at 11:08 PM Richi Dubey <richidubey at gmail.com> wrote:
> > It does. Thanks for your prompt response!
> > Also, how do I enable SMP tests and rtems-debug?
> I think the options are these:
> RTEMS_SMP = True
> RTEMS_DEBUG = True
> Add it to the config.ini file and configure it again before building.
> > On Fri, Apr 23, 2021 at 9:03 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> Hi Richi,
> >> On Fri, Apr 23, 2021 at 9:22 AM Richi Dubey <richidubey at gmail.com>
> wrote:
> >> > Hi,
> >> > I am building a new RTEMS from master source (to build the
> xilinx_zynqmp_lp64 bsp from the aarch64 arch), and these are the steps I
> followed:
> >> > mkdir -p $HOME/quick-start/src
> >> > cd $HOME/quick-start/src
> >> > git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> >> > git clone https://github.com/RTEMS/rtems.git
> >> > cd $HOME/quick-start/src/rsb/rtems
> >> > ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
> 6/rtems-aarch64
> >> >  export PATH=$HOME/quick-start/rtems/6/bin:"$PATH"
> >> > cd $HOME/quick-start/src/rtems
> >> > ./rtems-bootstrap
> >> > -And I get this error-:
> >> > 118/119: autoreconf: c/src/make/configure.ac
> >> > 119/119: autoreconf: cpukit/configure.ac
> >> > automake: error: cannot open < libnetworking/headers.am: No such
> file or directory
> >> > autoreconf: automake failed with exit status: 1
> >> > error: error: autoreconf: autoreconf -i --no-recursive
> >> > Bootstrap FAILED.
> >> Please try using waf.
> >> echo "[aarch64/xilinx_zynqmp_lp64]" > config.ini
> >> echo "BUILD_TESTS=True" >> config.ini
> >> ./waf configure
> >> ./waf
> >> ./waf install
> >> > Can someone please help me with this?
> >> I hope the above instructions will build it without issues.
> >> Best regards,
> >> Vijay
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210425/715abac7/attachment.html>
