RTEMS Bootstrap fails
Richi Dubey richidubey at gmail.com
Mon Apr 26 04:18:49 UTC 2021
Ok, thanks for the update.
On Sun, Apr 25, 2021 at 11:11 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> This error occurs because the AArch64 port does not yet support SMP. It’s
> on my list of things to do, but it’s likely a couple months before I start
> on that work.
> Kinsey
> *From:* devel <devel-bounces at rtems.org> *On Behalf Of *Richi Dubey
> *Sent:* Sunday, April 25, 2021 01:05
> *To:* Vijay Kumar Banerjee <vijay at rtems.org>
> *Cc:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Re: RTEMS Bootstrap fails
> Hi,
> The docs
> <https://docs.rtems.org/branches/master/user/bld/#migration-from-autoconf-automake>
> says RTEMS_SMP = True should work, but I get a warning:
> rdubey at hpc1:~/quick-start/src/rtems$ echo "RTEMS_SMP = True">>config.ini
> rdubey at hpc1:~/quick-start/src/rtems$ ./waf configure
> --prefix=/home/rdubey/quick-start/waf-path
> Setting top to                           :
> /home/rdubey/quick-start/src/rtems
> Setting out to                           :
> /home/rdubey/quick-start/src/rtems/build
> Configure board support package (BSP)    : aarch64/xilinx_zynqmp_lp64
> Checking for program 'aarch64-rtems6-gcc' :
> /home/rdubey/quick-start/rtems/6/bin/aarch64-rtems6-gcc
> Checking for program 'aarch64-rtems6-g++' :
> /home/rdubey/quick-start/rtems/6/bin/aarch64-rtems6-g++
> Checking for program 'aarch64-rtems6-ar'  :
> /home/rdubey/quick-start/rtems/6/bin/aarch64-rtems6-ar
> Checking for program 'aarch64-rtems6-ld'  :
> /home/rdubey/quick-start/rtems/6/bin/aarch64-rtems6-ld
> Checking for program 'ar'                 :
> Checking for program 'g++, c++'           :
> Checking for program 'gas, gcc'           :
> Checking for program 'gcc, cc'            :
> Checking for asm flags '-MMD'             : yes
> Checking for c flags '-MMD'               : yes
> Checking for cxx flags '-MMD'             : yes
> Checking for program 'rtems-bin2c'        :
> /home/rdubey/quick-start/rtems/6/bin/rtems-bin2c
> Checking for program 'gzip'               : /bin/gzip
> Checking for program 'rtems-ld'           :
> /home/rdubey/quick-start/rtems/6/bin/rtems-ld
> Checking for program 'rtems-syms'         :
> /home/rdubey/quick-start/rtems/6/bin/rtems-syms
> Checking for program 'xz'                 : /usr/bin/xz
> Unknown configuration option              : RTEMS_SMP
> 'configure' finished successfully (1.743s)
> On Sun, Apr 25, 2021 at 10:40 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> On Sat, Apr 24, 2021 at 11:08 PM Richi Dubey <richidubey at gmail.com> wrote:
> > It does. Thanks for your prompt response!
> > Also, how do I enable SMP tests and rtems-debug?
> I think the options are these:
> RTEMS_SMP = True
> RTEMS_DEBUG = True
> Add it to the config.ini file and configure it again before building.
> > On Fri, Apr 23, 2021 at 9:03 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> Hi Richi,
> >> On Fri, Apr 23, 2021 at 9:22 AM Richi Dubey <richidubey at gmail.com>
> wrote:
> >> > Hi,
> >> > I am building a new RTEMS from master source (to build the
> xilinx_zynqmp_lp64 bsp from the aarch64 arch), and these are the steps I
> followed:
> >> > mkdir -p $HOME/quick-start/src
> >> > cd $HOME/quick-start/src
> >> > git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> >> > git clone https://github.com/RTEMS/rtems.git
> >> > cd $HOME/quick-start/src/rsb/rtems
> >> > ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/6
> 6/rtems-aarch64
> >> >  export PATH=$HOME/quick-start/rtems/6/bin:"$PATH"
> >> > cd $HOME/quick-start/src/rtems
> >> > ./rtems-bootstrap
> >> > -And I get this error-:
> >> > 118/119: autoreconf: c/src/make/configure.ac
> >> > 119/119: autoreconf: cpukit/configure.ac
> >> > automake: error: cannot open < libnetworking/headers.am: No such
> file or directory
> >> > autoreconf: automake failed with exit status: 1
> >> > error: error: autoreconf: autoreconf -i --no-recursive
> >> > Bootstrap FAILED.
> >> Please try using waf.
> >> echo "[aarch64/xilinx_zynqmp_lp64]" > config.ini
> >> echo "BUILD_TESTS=True" >> config.ini
> >> ./waf configure
> >> ./waf
> >> ./waf install
> >> > Can someone please help me with this?
> >> I hope the above instructions will build it without issues.
> >> Best regards,
> >> Vijay
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210426/c2e750a0/attachment.html>
