[PATCH] c-user: Generate scheduling concepts documentation
Sebastian Huber
Fri Apr 23 19:15:24 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Here is the updated document for review:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
c-user/scheduling-concepts/directives.rst | 885 +++++++++++++-------
c-user/scheduling-concepts/introduction.rst | 86 +-
2 files changed, 646 insertions(+), 325 deletions(-)
diff --git a/c-user/scheduling-concepts/directives.rst b/c-user/scheduling-concepts/directives.rst
index 5b1246f..f80c5bd 100644
--- a/c-user/scheduling-concepts/directives.rst
+++ b/c-user/scheduling-concepts/directives.rst
@@ -1,424 +1,701 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2013, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated. If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual. The manual is provided as a part of
+.. a release. For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _SchedulerManagerDirectives:
Directives
-This section details the scheduler manager. A subsection is dedicated to each
-of these services and describes the calling sequence, related constants, usage,
-and status codes.
+This section details the directives of the Scheduler Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/scheduler/if/ident
.. raw:: latex
- \clearpage
+ \clearpage
-.. _rtems_scheduler_ident:
+.. index:: rtems_scheduler_ident()
-SCHEDULER_IDENT - Get ID of a scheduler
+.. _InterfaceRtemsSchedulerIdent:
+rtems_scheduler_ident()
+Identifies a scheduler by the object name.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+ rtems_status_code rtems_scheduler_ident( rtems_name name, rtems_id *id );
+.. rubric:: PARAMETERS:
+``name``
+ This parameter is the scheduler name to look up.
+``id``
+ This parameter is the pointer to an object identifier variable. When the
+ directive call is successful, the identifier of the scheduler will be
+ stored in this variable.
-CALLING SEQUENCE:
- .. code-block:: c
+.. rubric:: DESCRIPTION:
- rtems_status_code rtems_scheduler_ident(
- rtems_name name,
- rtems_id *id
+This directive obtains a scheduler identifier associated with the scheduler
+name specified in ``name``.
-DIRECTIVE STATUS CODES:
- .. list-table::
- :class: rtems-table
+.. rubric:: RETURN VALUES:
- * - ``RTEMS_SUCCESSFUL``
- - Successful operation.
- * - ``RTEMS_INVALID_ADDRESS``
- - The ``id`` parameter is ``NULL``.
- * - ``RTEMS_INVALID_NAME``
- - Invalid scheduler name.
+:c:macro:`RTEMS_SUCCESSFUL`
+ The requested operation was successful.
-DESCRIPTION:
- Identifies a scheduler by its name. The scheduler name is determined by
- the scheduler configuration. See :ref:`ConfigurationSchedulerTable`
- and :ref:`CONFIGURE_SCHEDULER_NAME`.
+:c:macro:`RTEMS_INVALID_NAME`
+ There was no scheduler associated with the name.
-NOTES:
- None.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+ The ``id`` parameter was `NULL
+ <https://en.cppreference.com/w/c/types/NULL>`_.
+.. rubric:: NOTES:
+The scheduler name is determined by the scheduler configuration.
+The scheduler identifier is used with other scheduler related directives to
+access the scheduler.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within any runtime context.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/scheduler/if/ident-by-processor
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_ident_by_processor()
+.. _InterfaceRtemsSchedulerIdentByProcessor:
-.. _rtems_scheduler_ident_by_processor:
+rtems_scheduler_ident_by_processor()
-SCHEDULER_IDENT_BY_PROCESSOR - Get ID of a scheduler by processor
+Identifies a scheduler by the processor index.
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_scheduler_ident_by_processor(
- uint32_t cpu_index,
- rtems_id *id
+.. code-block:: c
- .. list-table::
+ rtems_status_code rtems_scheduler_ident_by_processor(
+ uint32_t cpu_index,
+ rtems_id *id
- - Invalid processor index.
- * - ``RTEMS_INCORRECT_STATE``
- - The processor index is valid, however, this processor is not owned by
- a scheduler.
-DESCRIPTION:
- Identifies a scheduler by a processor.
+``cpu_index``
+ This parameter is the processor index to identify the scheduler.
-NOTES:
- None.
+``id``
+ The processor index was invalid.
+:c:macro:`RTEMS_INCORRECT_STATE`
+ The processor index was valid, however, the corresponding processor was not
+ owned by a scheduler.
+.. Generated from spec:/rtems/scheduler/if/ident-by-processor-set
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_ident_by_processor_set()
+.. _InterfaceRtemsSchedulerIdentByProcessorSet:
+rtems_scheduler_ident_by_processor_set()
+Identifies a scheduler by the processor set.
+.. code-block:: c
+ rtems_status_code rtems_scheduler_ident_by_processor_set(
+ size_t cpusetsize,
+ const cpu_set_t *cpuset,
+ rtems_id *id
+``cpusetsize``
+ This parameter is the size of the referenced processor set variable in
+ bytes. This value shall be positive.
+``cpuset``
+ This parameter is the pointer to a processor set variable. The referenced
+ processor set will be used to identify the scheduler.
-.. _rtems_scheduler_ident_by_processor_set:
+``id``
-SCHEDULER_IDENT_BY_PROCESSOR_SET - Get ID of a scheduler by processor set
-CALLING SEQUENCE:
- .. code-block:: c
+The scheduler is selected according to the highest numbered online processor in
+the specified processor set.
- rtems_status_code rtems_scheduler_ident_by_processor_set(
- size_t cpusetsize,
- const cpu_set_t *cpuset,
- rtems_id *id
- .. list-table::
- * - ``RTEMS_INVALID_SIZE``
- - Invalid processor set size.
- - The processor set contains no online processor.
- - The processor set is valid, however, the highest numbered online
- processor in the specified processor set is not owned by a scheduler.
-DESCRIPTION:
- Identifies a scheduler by a processor set. The scheduler is selected
- according to the highest numbered online processor in the specified
- processor set.
+:c:macro:`RTEMS_INVALID_SIZE`
+ The processor set size was invalid.
-NOTES:
- None.
+ The processor set contained no online processor.
+ The processor set was valid, however, the highest numbered online processor
+ in the processor set was not owned by a scheduler.
+.. Generated from spec:/rtems/scheduler/if/get-maximum-priority
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_get_maximum_priority()
+.. _InterfaceRtemsSchedulerGetMaximumPriority:
+rtems_scheduler_get_maximum_priority()
+Gets the maximum task priority of the scheduler.
-.. _rtems_scheduler_get_maximum_priority:
-SCHEDULER_GET_MAXIMUM_PRIORITY - Get maximum task priority of a scheduler
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ rtems_status_code rtems_scheduler_get_maximum_priority(
+ rtems_id scheduler_id,
+ rtems_task_priority *priority
- rtems_status_code rtems_scheduler_get_maximum_priority(
- rtems_id scheduler_id,
- rtems_task_priority *priority
- .. list-table::
+``scheduler_id``
+ This parameter is the scheduler identifier.
- * - ``RTEMS_INVALID_ID``
- - Invalid scheduler instance identifier.
- - The ``priority`` parameter is ``NULL``.
+``priority``
+ This parameter is the pointer to a task priority variable. The maximum
+ priority of the scheduler will be stored in this variable, if the operation
+ is successful.
-DESCRIPTION:
- Returns the maximum task priority of the specified scheduler instance in
- ``priority``.
-NOTES:
- None.
+:c:macro:`RTEMS_INVALID_ID`
+ There was no scheduler associated with the identifier specified by
+ ``scheduler_id``.
+ The ``priority`` parameter was `NULL
+.. Generated from spec:/rtems/scheduler/if/map-priority-to-posix
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_map_priority_to_posix()
-.. _rtems_scheduler_map_priority_to_posix:
+.. _InterfaceRtemsSchedulerMapPriorityToPosix:
+rtems_scheduler_map_priority_to_posix()
-SCHEDULER_MAP_PRIORITY_TO_POSIX - Map task priority to POSIX thread prority
+Maps a Classic API task priority to the corresponding POSIX thread priority.
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_scheduler_map_priority_to_posix(
- rtems_task_priority priority,
- int *posix_priority
+.. code-block:: c
- .. list-table::
+ rtems_status_code rtems_scheduler_map_priority_to_posix(
+ rtems_task_priority priority,
+ int *posix_priority
- - The ``posix_priority`` parameter is ``NULL``.
- * - ``RTEMS_INVALID_PRIORITY``
- - Invalid task priority.
-DESCRIPTION:
- Maps a task priority to the corresponding POSIX thread priority.
+``scheduler_id``
-NOTES:
- None.
+``priority``
+ This parameter is the Classic API task priority to map.
+``posix_priority``
+ This parameter is the pointer to a POSIX thread priority variable. When
+ the directive call is successful, the POSIX thread priority value
+ corresponding to the specified Classic API task priority value will be
+ The ``posix_priority`` parameter was `NULL
+ ``scheduler_id``.
+:c:macro:`RTEMS_INVALID_PRIORITY`
+ The Classic API task priority was invalid.
+.. Generated from spec:/rtems/scheduler/if/map-priority-from-posix
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_map_priority_from_posix()
+.. _InterfaceRtemsSchedulerMapPriorityFromPosix:
+rtems_scheduler_map_priority_from_posix()
+Maps a POSIX thread priority to the corresponding Classic API task priority.
+.. code-block:: c
+ rtems_status_code rtems_scheduler_map_priority_from_posix(
+ int posix_priority,
-.. _rtems_scheduler_map_priority_from_posix:
+``scheduler_id``
-SCHEDULER_MAP_PRIORITY_FROM_POSIX - Map POSIX thread prority to task priority
+``posix_priority``
+ This parameter is the POSIX thread priority to map.
-CALLING SEQUENCE:
- .. code-block:: c
+``priority``
+ This parameter is the pointer to a Classic API task priority variable.
+ When the directive call is successful, the Classic API task priority value
+ corresponding to the specified POSIX thread priority value will be stored
+ in this variable.
- rtems_status_code rtems_scheduler_map_priority_from_posix(
- int posix_priority,
- .. list-table::
- - Invalid POSIX thread priority.
-DESCRIPTION:
- Maps a POSIX thread priority to the corresponding task priority.
+ ``scheduler_id``.
-NOTES:
- None.
+ The POSIX thread priority was invalid.
+.. Generated from spec:/rtems/scheduler/if/get-processor
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_get_processor()
+.. _InterfaceRtemsSchedulerGetProcessor:
+rtems_scheduler_get_processor()
+Returns the index of the current processor.
-.. _rtems_scheduler_get_processor:
+.. code-block:: c
-SCHEDULER_GET_PROCESSOR - Get current processor index
+ uint32_t rtems_scheduler_get_processor( void );
-CALLING SEQUENCE:
- .. code-block:: c
- uint32_t rtems_scheduler_get_processor( void );
+Where the system was built with SMP support disabled, this directive evaluates
+to a compile time constant of zero.
- This directive returns the index of the current processor.
+Where the system was built with SMP support enabled, this directive returns the
+index of the current processor. The set of processor indices is the range of
+integers starting with zero up to
+:ref:`InterfaceRtemsSchedulerGetProcessorMaximum` minus one.
-DESCRIPTION:
- In uniprocessor configurations, a value of zero will be returned.
- In SMP configurations, an architecture specific method is used to obtain the
- index of the current processor in the system. The set of processor indices
- is the range of integers starting with zero up to the processor count minus
- one.
- Outside of sections with disabled thread dispatching the current processor
- index may change after every instruction since the thread may migrate from
- one processor to another. Sections with disabled interrupts are sections
- with thread dispatching disabled.
+.. rubric:: NOTES:
-NOTES:
- None.
+Outside of sections with disabled thread dispatching the current processor
+index may change after every instruction since the thread may migrate from one
+processor to another. Sections with disabled interrupts are sections with
+thread dispatching disabled.
+.. Generated from spec:/rtems/scheduler/if/get-processor-maximum
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_get_processor_maximum()
+.. _InterfaceRtemsSchedulerGetProcessorMaximum:
+rtems_scheduler_get_processor_maximum()
+Returns the processor maximum supported by the system.
-.. _rtems_scheduler_get_processor_maximum:
-SCHEDULER_GET_PROCESSOR_MAXIMUM - Get processor maximum
+.. code-block:: c
-CALLING SEQUENCE:
- .. code-block:: c
+ uint32_t rtems_scheduler_get_processor_maximum( void );
- uint32_t rtems_scheduler_get_processor_maximum( void );
- This directive returns the processor maximum supported by the system.
+to a compile time constant of one.
-DESCRIPTION:
- In uniprocessor configurations, a value of one will be returned.
+minimum of the processors (physically or virtually) available at the
+:term:`target` and the configured processor maximum (see
+:ref:`CONFIGURE_MAXIMUM_PROCESSORS`). Not all processors in the range from
+processor index zero to the last processor index (which is the processor
+maximum minus one) may be configured to be used by a scheduler or may be online
+(online processors have a scheduler assigned).
- In SMP configurations, this directive returns the minimum of the processors
- (physically or virtually) available by the platform and the configured
- processor maximum. Not all processors in the range from processor index
- zero to the last processor index (which is the processor maximum minus one)
- may be configured to be used by a scheduler or online (online processors
- have a scheduler assigned).
-NOTES:
- None.
+.. Generated from spec:/rtems/scheduler/if/get-processor-set
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_get_processor_set()
+.. _InterfaceRtemsSchedulerGetProcessorSet:
+rtems_scheduler_get_processor_set()
+Gets the set of processors owned by the scheduler.
-.. _rtems_scheduler_get_processor_set:
+.. code-block:: c
-SCHEDULER_GET_PROCESSOR_SET - Get processor set of a scheduler
+ rtems_status_code rtems_scheduler_get_processor_set(
+ cpu_set_t *cpuset
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_scheduler_get_processor_set(
- cpu_set_t *cpuset
+``scheduler_id``
- .. list-table::
+``cpusetsize``
- - The ``cpuset`` parameter is ``NULL``.
- * - ``RTEMS_INVALID_NUMBER``
- - The processor set buffer is too small for the set of processors owned
- by the scheduler instance.
+``cpuset``
+ This parameter is the pointer to a processor set variable. When the
+ directive call is successful, the processor set of the scheduler will be
+ stored in this variable. A set bit in the processor set means that the
+ corresponding processor is owned by the scheduler, otherwise the bit is
+ cleared.
-DESCRIPTION:
- Returns the processor set owned by the scheduler instance in ``cpuset``. A
- set bit in the processor set means that this processor is owned by the
- scheduler instance and a cleared bit means the opposite.
-NOTES:
- None.
+ The ``cpuset`` parameter was `NULL
+ ``scheduler_id``.
+:c:macro:`RTEMS_INVALID_NUMBER`
+ The provided processor set was too small for the set of processors owned by
+ the scheduler.
+.. Generated from spec:/rtems/scheduler/if/add-processor
.. raw:: latex
- \clearpage
+ \clearpage
+.. index:: rtems_scheduler_add_processor()
-.. _rtems_scheduler_add_processor:
+.. _InterfaceRtemsSchedulerAddProcessor:
-SCHEDULER_ADD_PROCESSOR - Add processor to a scheduler
+rtems_scheduler_add_processor()
-CALLING SEQUENCE:
- .. code-block:: c
+Adds the processor to the set of processors owned by the scheduler.
- rtems_status_code rtems_scheduler_add_processor(
- .. list-table::
+.. code-block:: c
- * - ``RTEMS_NOT_CONFIGURED``
- - The processor is not configured to be used by the application.
- - The processor is configured to be used by the application, however, it
- is not online.
- * - ``RTEMS_RESOURCE_IN_USE``
- - The processor is already assigned to a scheduler instance.
+ rtems_status_code rtems_scheduler_add_processor(
-DESCRIPTION:
- Adds a processor to the set of processors owned by the specified scheduler
- instance.
-NOTES:
- Must be called from task context. This operation obtains and releases the
- objects allocator lock.
+``scheduler_id``
+``cpu_index``
+ This parameter is the index of the processor to add.
+This directive adds the processor specified by the ``cpu_index`` to the
+scheduler specified by ``scheduler_id``.
+ ``scheduler_id``.
+:c:macro:`RTEMS_NOT_CONFIGURED`
+ The processor was not configured to be used by the application.
+ The processor was configured to be used by the application, however, it was
+ not online.
+:c:macro:`RTEMS_RESOURCE_IN_USE`
+ The processor was already assigned to a scheduler.
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex. This may
+ cause the calling task to be preempted.
+.. Generated from spec:/rtems/scheduler/if/remove-processor
.. raw:: latex
- \clearpage
-.. _rtems_scheduler_remove_processor:
-SCHEDULER_REMOVE_PROCESSOR - Remove processor from a scheduler
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_scheduler_remove_processor(
- .. list-table::
- - The processor is not owned by the specified scheduler instance.
- - The set of processors owned by the specified scheduler instance would
- be empty after the processor removal and there exists a non-idle task
- that uses this scheduler instance as its home scheduler instance.
- - A task with a restricted processor affinity exists that uses this
- scheduler instance as its home scheduler instance and it would be no
- longer possible to allocate a processor for this task after the
- removal of this processor.
-DESCRIPTION:
- Removes a processor from set of processors owned by the specified scheduler
- instance.
-NOTES:
- objects allocator lock. Removing a processor from a scheduler is a complex
- operation that involves all tasks of the system.
+ \clearpage
+.. index:: rtems_scheduler_remove_processor()
+.. _InterfaceRtemsSchedulerRemoveProcessor:
+rtems_scheduler_remove_processor()
+Removes the processor from the set of processors owned by the scheduler.
+.. code-block:: c
+ rtems_status_code rtems_scheduler_remove_processor(
+``scheduler_id``
+``cpu_index``
+ This parameter is the index of the processor to remove.
+This directive removes the processor specified by the ``cpu_index`` from the
+ ``scheduler_id``.
+ The processor was not owned by the scheduler.
+ The set of processors owned by the scheduler would have been empty after
+ the processor removal and there was at least one non-idle task that used
+ this scheduler as its :term:`home scheduler`.
+.. rubric:: NOTES:
+Removing a processor from a scheduler is a complex operation that involves all
+tasks of the system.
diff --git a/c-user/scheduling-concepts/introduction.rst b/c-user/scheduling-concepts/introduction.rst
index 92da6de..31de1c1 100644
--- a/c-user/scheduling-concepts/introduction.rst
+++ b/c-user/scheduling-concepts/introduction.rst
@@ -1,42 +1,86 @@
+.. Generated from spec:/rtems/scheduler/if/group
+.. _SchedulerManagerIntroduction:
Introduction
+.. The following list was generated from:
+.. spec:/rtems/scheduler/if/ident
+.. spec:/rtems/scheduler/if/ident-by-processor
+.. spec:/rtems/scheduler/if/ident-by-processor-set
+.. spec:/rtems/scheduler/if/get-maximum-priority
+.. spec:/rtems/scheduler/if/map-priority-to-posix
+.. spec:/rtems/scheduler/if/map-priority-from-posix
+.. spec:/rtems/scheduler/if/get-processor
+.. spec:/rtems/scheduler/if/get-processor-maximum
+.. spec:/rtems/scheduler/if/get-processor-set
+.. spec:/rtems/scheduler/if/add-processor
+.. spec:/rtems/scheduler/if/remove-processor
+The scheduling concepts relate to the allocation of processing time for tasks.
The concept of scheduling in real-time systems dictates the ability to provide
-an immediate response to specific external events, particularly the necessity of
-scheduling tasks to run within a specified time limit after the occurrence of
-an event. For example, software embedded in life-support systems used to
-monitor hospital patients must take instant action if a change in the patient's
+an immediate response to specific external events, particularly the necessity
+of scheduling tasks to run within a specified time limit after the occurrence
+of an event. For example, software embedded in life-support systems used to
+monitor hospital patients must take instant action if a change in the patient’s
status is detected.
The component of RTEMS responsible for providing this capability is
-appropriately called the scheduler. The scheduler's sole purpose is to
-allocate the all important resource of processor time to the various tasks
-competing for attention.
-The directives provided by the scheduler manager are:
+appropriately called the scheduler. The scheduler’s sole purpose is to allocate
+the all important resource of processor time to the various tasks competing for
+attention. The directives provided by the Scheduler Manager are:
-- :ref:`rtems_scheduler_ident`
+* :ref:`InterfaceRtemsSchedulerIdent` - Identifies a scheduler by the object
+ name.
-- :ref:`rtems_scheduler_ident_by_processor`
+* :ref:`InterfaceRtemsSchedulerIdentByProcessor` - Identifies a scheduler by
+ the processor index.
-- :ref:`rtems_scheduler_ident_by_processor_set`
+* :ref:`InterfaceRtemsSchedulerIdentByProcessorSet` - Identifies a scheduler by
+ the processor set.
-- :ref:`rtems_scheduler_get_maximum_priority`
+* :ref:`InterfaceRtemsSchedulerGetMaximumPriority` - Gets the maximum task
+ priority of the scheduler.
-- :ref:`rtems_scheduler_map_priority_to_posix`
+* :ref:`InterfaceRtemsSchedulerMapPriorityToPosix` - Maps a Classic API task
+ priority to the corresponding POSIX thread priority.
-- :ref:`rtems_scheduler_map_priority_from_posix`
+* :ref:`InterfaceRtemsSchedulerMapPriorityFromPosix` - Maps a POSIX thread
+ priority to the corresponding Classic API task priority.
-- :ref:`rtems_scheduler_get_processor`
+* :ref:`InterfaceRtemsSchedulerGetProcessor` - Returns the index of the current
+ processor.
-- :ref:`rtems_scheduler_get_processor_maximum`
+* :ref:`InterfaceRtemsSchedulerGetProcessorMaximum` - Returns the processor
+ maximum supported by the system.
-- :ref:`rtems_scheduler_get_processor_set`
+* :ref:`InterfaceRtemsSchedulerGetProcessorSet` - Gets the set of processors
+ owned by the scheduler.
-- :ref:`rtems_scheduler_add_processor`
+* :ref:`InterfaceRtemsSchedulerAddProcessor` - Adds the processor to the set of
+ processors owned by the scheduler.
-- :ref:`rtems_scheduler_remove_processor`
+* :ref:`InterfaceRtemsSchedulerRemoveProcessor` - Removes the processor from
+ the set of processors owned by the scheduler.
2.26.2
