[PATCH] c-user: Generate scheduling concepts documentation
Mon Apr 26 19:15:19 UTC 2021
looks good.
On Fri, Apr 23, 2021 at 1:15 PM Sebastian Huber
> The documentation is a consolidation of the comments in Doxygen markup
> and the documentation sources in Sphinx markup.  The documentation was
> transfered to interface specification items.  The documentation source
> files were generated from the items by a script.
> Update #3993.
> Here is the updated document for review:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
>  c-user/scheduling-concepts/directives.rst   | 885 +++++++++++++-------
>  c-user/scheduling-concepts/introduction.rst |  86 +-
>  2 files changed, 646 insertions(+), 325 deletions(-)
> diff --git a/c-user/scheduling-concepts/directives.rst b/c-user/scheduling-concepts/directives.rst
> index 5b1246f..f80c5bd 100644
> --- a/c-user/scheduling-concepts/directives.rst
> +++ b/c-user/scheduling-concepts/directives.rst
> @@ -1,424 +1,701 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> -.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> +.. Copyright (C) 2013, 2021 embedded brains GmbH (http://www.embedded-brains.de)
> +.. Copyright (C) 1988, 2017 On-Line Applications Research Corporation (OAR)
> +.. This file is part of the RTEMS quality process and was automatically
> +.. generated.  If you find something that needs to be fixed or
> +.. worded better please post a report or patch to an RTEMS mailing list
> +.. or raise a bug report:
> +.. https://www.rtems.org/bugs.html
> +.. For information on updating and regenerating please refer to the How-To
> +.. section in the Software Requirements Engineering chapter of the
> +.. RTEMS Software Engineering manual.  The manual is provided as a part of
> +.. a release.  For development sources please refer to the online
> +.. documentation at:
> +.. https://docs.rtems.org
> +.. _SchedulerManagerDirectives:
>  Directives
> -This section details the scheduler manager.  A subsection is dedicated to each
> -of these services and describes the calling sequence, related constants, usage,
> -and status codes.
> +This section details the directives of the Scheduler Manager. A subsection is
> +dedicated to each of this manager's directives and lists the calling sequence,
> +parameters, description, return values, and notes of the directive.
> +.. Generated from spec:/rtems/scheduler/if/ident
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> -.. _rtems_scheduler_ident:
> +.. index:: rtems_scheduler_ident()
> -SCHEDULER_IDENT - Get ID of a scheduler
> +.. _InterfaceRtemsSchedulerIdent:
> +rtems_scheduler_ident()
> +Identifies a scheduler by the object name.
> +.. rubric:: CALLING SEQUENCE:
> +.. code-block:: c
> +    rtems_status_code rtems_scheduler_ident( rtems_name name, rtems_id *id );
> +.. rubric:: PARAMETERS:
> +``name``
> +    This parameter is the scheduler name to look up.
> +``id``
> +    This parameter is the pointer to an object identifier variable.  When the
> +    directive call is successful, the identifier of the scheduler will be
> +    stored in this variable.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +.. rubric:: DESCRIPTION:
> -        rtems_status_code rtems_scheduler_ident(
> -            rtems_name  name,
> -            rtems_id   *id
> +This directive obtains a scheduler identifier associated with the scheduler
> +name specified in ``name``.
> -DIRECTIVE STATUS CODES:
> -    .. list-table::
> -     :class: rtems-table
> +.. rubric:: RETURN VALUES:
> -     * - ``RTEMS_SUCCESSFUL``
> -       - Successful operation.
> -     * - ``RTEMS_INVALID_ADDRESS``
> -       - The ``id`` parameter is ``NULL``.
> -     * - ``RTEMS_INVALID_NAME``
> -       - Invalid scheduler name.
> +:c:macro:`RTEMS_SUCCESSFUL`
> +    The requested operation was successful.
> -DESCRIPTION:
> -    Identifies a scheduler by its name.  The scheduler name is determined by
> -    the scheduler configuration.  See :ref:`ConfigurationSchedulerTable`
> -    and :ref:`CONFIGURE_SCHEDULER_NAME`.
> +:c:macro:`RTEMS_INVALID_NAME`
> +    There was no scheduler associated with the name.
> -NOTES:
> -    None.
> +:c:macro:`RTEMS_INVALID_ADDRESS`
> +    The ``id`` parameter was `NULL
> +    <https://en.cppreference.com/w/c/types/NULL>`_.
> +.. rubric:: NOTES:
> +The scheduler name is determined by the scheduler configuration.
> +The scheduler identifier is used with other scheduler related directives to
> +access the scheduler.
> +.. rubric:: CONSTRAINTS:
> +The following constraints apply to this directive:
> +* The directive may be called from within any runtime context.
> +* The directive will not cause the calling task to be preempted.
> +.. Generated from spec:/rtems/scheduler/if/ident-by-processor
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_ident_by_processor()
> +.. _InterfaceRtemsSchedulerIdentByProcessor:
> -.. _rtems_scheduler_ident_by_processor:
> +rtems_scheduler_ident_by_processor()
> -SCHEDULER_IDENT_BY_PROCESSOR - Get ID of a scheduler by processor
> +Identifies a scheduler by the processor index.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_scheduler_ident_by_processor(
> -            uint32_t  cpu_index,
> -            rtems_id *id
> +.. code-block:: c
> -    .. list-table::
> +    rtems_status_code rtems_scheduler_ident_by_processor(
> +      uint32_t  cpu_index,
> +      rtems_id *id
> -       - Invalid processor index.
> -     * - ``RTEMS_INCORRECT_STATE``
> -       - The processor index is valid, however, this processor is not owned by
> -         a scheduler.
> -DESCRIPTION:
> -    Identifies a scheduler by a processor.
> +``cpu_index``
> +    This parameter is the processor index to identify the scheduler.
> -NOTES:
> -    None.
> +``id``
> +    The processor index was invalid.
> +:c:macro:`RTEMS_INCORRECT_STATE`
> +    The processor index was valid, however, the corresponding processor was not
> +    owned by a scheduler.
> +.. Generated from spec:/rtems/scheduler/if/ident-by-processor-set
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_ident_by_processor_set()
> +.. _InterfaceRtemsSchedulerIdentByProcessorSet:
> +rtems_scheduler_ident_by_processor_set()
> +Identifies a scheduler by the processor set.
> +.. code-block:: c
> +    rtems_status_code rtems_scheduler_ident_by_processor_set(
> +      size_t           cpusetsize,
> +      const cpu_set_t *cpuset,
> +      rtems_id        *id
> +``cpusetsize``
> +    This parameter is the size of the referenced processor set variable in
> +    bytes.  This value shall be positive.
> +``cpuset``
> +    This parameter is the pointer to a processor set variable.  The referenced
> +    processor set will be used to identify the scheduler.
> -.. _rtems_scheduler_ident_by_processor_set:
> +``id``
> -SCHEDULER_IDENT_BY_PROCESSOR_SET - Get ID of a scheduler by processor set
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +The scheduler is selected according to the highest numbered online processor in
> +the specified processor set.
> -        rtems_status_code rtems_scheduler_ident_by_processor_set(
> -            size_t           cpusetsize,
> -            const cpu_set_t *cpuset,
> -            rtems_id        *id
> -    .. list-table::
> -     * - ``RTEMS_INVALID_SIZE``
> -       - Invalid processor set size.
> -       - The processor set contains no online processor.
> -       - The processor set is valid, however, the highest numbered online
> -         processor in the specified processor set is not owned by a scheduler.
> -DESCRIPTION:
> -    Identifies a scheduler by a processor set.  The scheduler is selected
> -    according to the highest numbered online processor in the specified
> -    processor set.
> +:c:macro:`RTEMS_INVALID_SIZE`
> +    The processor set size was invalid.
> -NOTES:
> -    None.
> +    The processor set contained no online processor.
> +    The processor set was valid, however, the highest numbered online processor
> +    in the processor set was not owned by a scheduler.
> +.. Generated from spec:/rtems/scheduler/if/get-maximum-priority
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_get_maximum_priority()
> +.. _InterfaceRtemsSchedulerGetMaximumPriority:
> +rtems_scheduler_get_maximum_priority()
> +Gets the maximum task priority of the scheduler.
> -.. _rtems_scheduler_get_maximum_priority:
> -SCHEDULER_GET_MAXIMUM_PRIORITY - Get maximum task priority of a scheduler
> +.. code-block:: c
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +    rtems_status_code rtems_scheduler_get_maximum_priority(
> +      rtems_id             scheduler_id,
> +      rtems_task_priority *priority
> -        rtems_status_code rtems_scheduler_get_maximum_priority(
> -            rtems_id             scheduler_id,
> -            rtems_task_priority *priority
> -    .. list-table::
> +``scheduler_id``
> +    This parameter is the scheduler identifier.
> -     * - ``RTEMS_INVALID_ID``
> -       - Invalid scheduler instance identifier.
> -       - The ``priority`` parameter is ``NULL``.
> +``priority``
> +    This parameter is the pointer to a task priority variable.  The maximum
> +    priority of the scheduler will be stored in this variable, if the operation
> +    is successful.
> -DESCRIPTION:
> -    Returns the maximum task priority of the specified scheduler instance in
> -    ``priority``.
> -NOTES:
> -    None.
> +:c:macro:`RTEMS_INVALID_ID`
> +    There was no scheduler associated with the identifier specified by
> +    ``scheduler_id``.
> +    The ``priority`` parameter was `NULL
> +.. Generated from spec:/rtems/scheduler/if/map-priority-to-posix
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_map_priority_to_posix()
> -.. _rtems_scheduler_map_priority_to_posix:
> +.. _InterfaceRtemsSchedulerMapPriorityToPosix:
> +rtems_scheduler_map_priority_to_posix()
> -SCHEDULER_MAP_PRIORITY_TO_POSIX - Map task priority to POSIX thread prority
> +Maps a Classic API task priority to the corresponding POSIX thread priority.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_scheduler_map_priority_to_posix(
> -            rtems_task_priority  priority,
> -            int                 *posix_priority
> +.. code-block:: c
> -    .. list-table::
> +    rtems_status_code rtems_scheduler_map_priority_to_posix(
> +      rtems_task_priority priority,
> +      int                *posix_priority
> -       - The ``posix_priority`` parameter is ``NULL``.
> -     * - ``RTEMS_INVALID_PRIORITY``
> -       - Invalid task priority.
> -DESCRIPTION:
> -    Maps a task priority to the corresponding POSIX thread priority.
> +``scheduler_id``
> -NOTES:
> -    None.
> +``priority``
> +    This parameter is the Classic API task priority to map.
> +``posix_priority``
> +    This parameter is the pointer to a POSIX thread priority variable.  When
> +    the directive call is successful, the POSIX thread priority value
> +    corresponding to the specified Classic API task priority value will be
> +    The ``posix_priority`` parameter was `NULL
> +    ``scheduler_id``.
> +:c:macro:`RTEMS_INVALID_PRIORITY`
> +    The Classic API task priority was invalid.
> +.. Generated from spec:/rtems/scheduler/if/map-priority-from-posix
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_map_priority_from_posix()
> +.. _InterfaceRtemsSchedulerMapPriorityFromPosix:
> +rtems_scheduler_map_priority_from_posix()
> +Maps a POSIX thread priority to the corresponding Classic API task priority.
> +.. code-block:: c
> +    rtems_status_code rtems_scheduler_map_priority_from_posix(
> +      int                  posix_priority,
> -.. _rtems_scheduler_map_priority_from_posix:
> +``scheduler_id``
> -SCHEDULER_MAP_PRIORITY_FROM_POSIX - Map POSIX thread prority to task priority
> +``posix_priority``
> +    This parameter is the POSIX thread priority to map.
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +``priority``
> +    This parameter is the pointer to a Classic API task priority variable.
> +    When the directive call is successful, the Classic API task priority value
> +    corresponding to the specified POSIX thread priority value will be stored
> +    in this variable.
> -        rtems_status_code rtems_scheduler_map_priority_from_posix(
> -            int                  posix_priority,
> -    .. list-table::
> -       - Invalid POSIX thread priority.
> -DESCRIPTION:
> -    Maps a POSIX thread priority to the corresponding task priority.
> +    ``scheduler_id``.
> -NOTES:
> -    None.
> +    The POSIX thread priority was invalid.
> +.. Generated from spec:/rtems/scheduler/if/get-processor
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_get_processor()
> +.. _InterfaceRtemsSchedulerGetProcessor:
> +rtems_scheduler_get_processor()
> +Returns the index of the current processor.
> -.. _rtems_scheduler_get_processor:
> +.. code-block:: c
> -SCHEDULER_GET_PROCESSOR - Get current processor index
> +    uint32_t rtems_scheduler_get_processor( void );
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        uint32_t rtems_scheduler_get_processor( void );
> +Where the system was built with SMP support disabled, this directive evaluates
> +to a compile time constant of zero.
> -    This directive returns the index of the current processor.
> +Where the system was built with SMP support enabled, this directive returns the
> +index of the current processor.  The set of processor indices is the range of
> +integers starting with zero up to
> +:ref:`InterfaceRtemsSchedulerGetProcessorMaximum` minus one.
> -DESCRIPTION:
> -    In uniprocessor configurations, a value of zero will be returned.
> -    In SMP configurations, an architecture specific method is used to obtain the
> -    index of the current processor in the system.  The set of processor indices
> -    is the range of integers starting with zero up to the processor count minus
> -    one.
> -    Outside of sections with disabled thread dispatching the current processor
> -    index may change after every instruction since the thread may migrate from
> -    one processor to another.  Sections with disabled interrupts are sections
> -    with thread dispatching disabled.
> +.. rubric:: NOTES:
> -NOTES:
> -    None.
> +Outside of sections with disabled thread dispatching the current processor
> +index may change after every instruction since the thread may migrate from one
> +processor to another.  Sections with disabled interrupts are sections with
> +thread dispatching disabled.
> +.. Generated from spec:/rtems/scheduler/if/get-processor-maximum
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_get_processor_maximum()
> +.. _InterfaceRtemsSchedulerGetProcessorMaximum:
> +rtems_scheduler_get_processor_maximum()
> +Returns the processor maximum supported by the system.
> -.. _rtems_scheduler_get_processor_maximum:
> -SCHEDULER_GET_PROCESSOR_MAXIMUM - Get processor maximum
> +.. code-block:: c
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +    uint32_t rtems_scheduler_get_processor_maximum( void );
> -        uint32_t rtems_scheduler_get_processor_maximum( void );
> -    This directive returns the processor maximum supported by the system.
> +to a compile time constant of one.
> -DESCRIPTION:
> -    In uniprocessor configurations, a value of one will be returned.
> +minimum of the processors (physically or virtually) available at the
> +:term:`target` and the configured processor maximum (see
> +:ref:`CONFIGURE_MAXIMUM_PROCESSORS`).  Not all processors in the range from
> +processor index zero to the last processor index (which is the processor
> +maximum minus one) may be configured to be used by a scheduler or may be online
> +(online processors have a scheduler assigned).
> -    In SMP configurations, this directive returns the minimum of the processors
> -    (physically or virtually) available by the platform and the configured
> -    processor maximum.  Not all processors in the range from processor index
> -    zero to the last processor index (which is the processor maximum minus one)
> -    may be configured to be used by a scheduler or online (online processors
> -    have a scheduler assigned).
> -NOTES:
> -    None.
> +.. Generated from spec:/rtems/scheduler/if/get-processor-set
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_get_processor_set()
> +.. _InterfaceRtemsSchedulerGetProcessorSet:
> +rtems_scheduler_get_processor_set()
> +Gets the set of processors owned by the scheduler.
> -.. _rtems_scheduler_get_processor_set:
> +.. code-block:: c
> -SCHEDULER_GET_PROCESSOR_SET - Get processor set of a scheduler
> +    rtems_status_code rtems_scheduler_get_processor_set(
> +      cpu_set_t *cpuset
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_scheduler_get_processor_set(
> -            cpu_set_t *cpuset
> +``scheduler_id``
> -    .. list-table::
> +``cpusetsize``
> -       - The ``cpuset`` parameter is ``NULL``.
> -     * - ``RTEMS_INVALID_NUMBER``
> -       - The processor set buffer is too small for the set of processors owned
> -         by the scheduler instance.
> +``cpuset``
> +    This parameter is the pointer to a processor set variable.  When the
> +    directive call is successful, the processor set of the scheduler will be
> +    stored in this variable.  A set bit in the processor set means that the
> +    corresponding processor is owned by the scheduler, otherwise the bit is
> +    cleared.
> -DESCRIPTION:
> -    Returns the processor set owned by the scheduler instance in ``cpuset``.  A
> -    set bit in the processor set means that this processor is owned by the
> -    scheduler instance and a cleared bit means the opposite.
> -NOTES:
> -    None.
> +    The ``cpuset`` parameter was `NULL
> +    ``scheduler_id``.
> +:c:macro:`RTEMS_INVALID_NUMBER`
> +    The provided processor set was too small for the set of processors owned by
> +    the scheduler.
> +.. Generated from spec:/rtems/scheduler/if/add-processor
>  .. raw:: latex
> -   \clearpage
> +    \clearpage
> +.. index:: rtems_scheduler_add_processor()
> -.. _rtems_scheduler_add_processor:
> +.. _InterfaceRtemsSchedulerAddProcessor:
> -SCHEDULER_ADD_PROCESSOR - Add processor to a scheduler
> +rtems_scheduler_add_processor()
> -CALLING SEQUENCE:
> -    .. code-block:: c
> +Adds the processor to the set of processors owned by the scheduler.
> -        rtems_status_code rtems_scheduler_add_processor(
> -    .. list-table::
> +.. code-block:: c
> -     * - ``RTEMS_NOT_CONFIGURED``
> -       - The processor is not configured to be used by the application.
> -       - The processor is configured to be used by the application, however, it
> -         is not online.
> -     * - ``RTEMS_RESOURCE_IN_USE``
> -       - The processor is already assigned to a scheduler instance.
> +    rtems_status_code rtems_scheduler_add_processor(
> -DESCRIPTION:
> -    Adds a processor to the set of processors owned by the specified scheduler
> -    instance.
> -NOTES:
> -    Must be called from task context.  This operation obtains and releases the
> -    objects allocator lock.
> +``scheduler_id``
> +``cpu_index``
> +    This parameter is the index of the processor to add.
> +This directive adds the processor specified by the ``cpu_index`` to the
> +scheduler specified by ``scheduler_id``.
> +    ``scheduler_id``.
> +:c:macro:`RTEMS_NOT_CONFIGURED`
> +    The processor was not configured to be used by the application.
> +    The processor was configured to be used by the application, however, it was
> +    not online.
> +:c:macro:`RTEMS_RESOURCE_IN_USE`
> +    The processor was already assigned to a scheduler.
> +* The directive may be called from within device driver initialization context.
> +* The directive may be called from within task context.
> +* The directive may obtain and release the object allocator mutex.  This may
> +  cause the calling task to be preempted.
> +.. Generated from spec:/rtems/scheduler/if/remove-processor
>  .. raw:: latex
> -   \clearpage
> -.. _rtems_scheduler_remove_processor:
> -SCHEDULER_REMOVE_PROCESSOR - Remove processor from a scheduler
> -CALLING SEQUENCE:
> -    .. code-block:: c
> -        rtems_status_code rtems_scheduler_remove_processor(
> -    .. list-table::
> -       - The processor is not owned by the specified scheduler instance.
> -       - The set of processors owned by the specified scheduler instance would
> -         be empty after the processor removal and there exists a non-idle task
> -         that uses this scheduler instance as its home scheduler instance.
> -       - A task with a restricted processor affinity exists that uses this
> -         scheduler instance as its home scheduler instance and it would be no
> -         longer possible to allocate a processor for this task after the
> -         removal of this processor.
> -DESCRIPTION:
> -    Removes a processor from set of processors owned by the specified scheduler
> -    instance.
> -NOTES:
> -    objects allocator lock.  Removing a processor from a scheduler is a complex
> -    operation that involves all tasks of the system.
> +    \clearpage
> +.. index:: rtems_scheduler_remove_processor()
> +.. _InterfaceRtemsSchedulerRemoveProcessor:
> +rtems_scheduler_remove_processor()
> +Removes the processor from the set of processors owned by the scheduler.
> +.. code-block:: c
> +    rtems_status_code rtems_scheduler_remove_processor(
> +``scheduler_id``
> +``cpu_index``
> +    This parameter is the index of the processor to remove.
> +This directive removes the processor specified by the ``cpu_index`` from the
> +    ``scheduler_id``.
> +    The processor was not owned by the scheduler.
> +    The set of processors owned by the scheduler would have been empty after
> +    the processor removal and there was at least one non-idle task that used
> +    this scheduler as its :term:`home scheduler`.
> +.. rubric:: NOTES:
> +Removing a processor from a scheduler is a complex operation that involves all
> +tasks of the system.
> diff --git a/c-user/scheduling-concepts/introduction.rst b/c-user/scheduling-concepts/introduction.rst
> index 92da6de..31de1c1 100644
> --- a/c-user/scheduling-concepts/introduction.rst
> +++ b/c-user/scheduling-concepts/introduction.rst
> @@ -1,42 +1,86 @@
> +.. Generated from spec:/rtems/scheduler/if/group
> +.. _SchedulerManagerIntroduction:
>  Introduction
> +.. The following list was generated from:
> +.. spec:/rtems/scheduler/if/ident
> +.. spec:/rtems/scheduler/if/ident-by-processor
> +.. spec:/rtems/scheduler/if/ident-by-processor-set
> +.. spec:/rtems/scheduler/if/get-maximum-priority
> +.. spec:/rtems/scheduler/if/map-priority-to-posix
> +.. spec:/rtems/scheduler/if/map-priority-from-posix
> +.. spec:/rtems/scheduler/if/get-processor
> +.. spec:/rtems/scheduler/if/get-processor-maximum
> +.. spec:/rtems/scheduler/if/get-processor-set
> +.. spec:/rtems/scheduler/if/add-processor
> +.. spec:/rtems/scheduler/if/remove-processor
> +The scheduling concepts relate to the allocation of processing time for tasks.
>  The concept of scheduling in real-time systems dictates the ability to provide
> -an immediate response to specific external events, particularly the necessity of
> -scheduling tasks to run within a specified time limit after the occurrence of
> -an event.  For example, software embedded in life-support systems used to
> -monitor hospital patients must take instant action if a change in the patient's
> +an immediate response to specific external events, particularly the necessity
> +of scheduling tasks to run within a specified time limit after the occurrence
> +of an event. For example, software embedded in life-support systems used to
> +monitor hospital patients must take instant action if a change in the patient’s
>  status is detected.
>  The component of RTEMS responsible for providing this capability is
> -appropriately called the scheduler.  The scheduler's sole purpose is to
> -allocate the all important resource of processor time to the various tasks
> -competing for attention.
> -The directives provided by the scheduler manager are:
> +appropriately called the scheduler. The scheduler’s sole purpose is to allocate
> +the all important resource of processor time to the various tasks competing for
> +attention. The directives provided by the Scheduler Manager are:
> -- :ref:`rtems_scheduler_ident`
> +* :ref:`InterfaceRtemsSchedulerIdent` - Identifies a scheduler by the object
> +  name.
> -- :ref:`rtems_scheduler_ident_by_processor`
> +* :ref:`InterfaceRtemsSchedulerIdentByProcessor` - Identifies a scheduler by
> +  the processor index.
> -- :ref:`rtems_scheduler_ident_by_processor_set`
> +* :ref:`InterfaceRtemsSchedulerIdentByProcessorSet` - Identifies a scheduler by
> +  the processor set.
> -- :ref:`rtems_scheduler_get_maximum_priority`
> +* :ref:`InterfaceRtemsSchedulerGetMaximumPriority` - Gets the maximum task
> +  priority of the scheduler.
> -- :ref:`rtems_scheduler_map_priority_to_posix`
> +* :ref:`InterfaceRtemsSchedulerMapPriorityToPosix` - Maps a Classic API task
> +  priority to the corresponding POSIX thread priority.
> -- :ref:`rtems_scheduler_map_priority_from_posix`
> +* :ref:`InterfaceRtemsSchedulerMapPriorityFromPosix` - Maps a POSIX thread
> +  priority to the corresponding Classic API task priority.
> -- :ref:`rtems_scheduler_get_processor`
> +* :ref:`InterfaceRtemsSchedulerGetProcessor` - Returns the index of the current
> +  processor.
> -- :ref:`rtems_scheduler_get_processor_maximum`
> +* :ref:`InterfaceRtemsSchedulerGetProcessorMaximum` - Returns the processor
> +  maximum supported by the system.
> -- :ref:`rtems_scheduler_get_processor_set`
> +* :ref:`InterfaceRtemsSchedulerGetProcessorSet` - Gets the set of processors
> +  owned by the scheduler.
> -- :ref:`rtems_scheduler_add_processor`
> +* :ref:`InterfaceRtemsSchedulerAddProcessor` - Adds the processor to the set of
> +  processors owned by the scheduler.
> -- :ref:`rtems_scheduler_remove_processor`
> +* :ref:`InterfaceRtemsSchedulerRemoveProcessor` - Removes the processor from
> +  the set of processors owned by the scheduler.
> 2.26.2
> devel mailing list
> devel at rtems.org
