tcpreplay for testing network stacks
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Apr 28 06:41:39 UTC 2021
Hello Vijay,
Am 27.04.21 um 18:48 schrieb Vijay Kumar Banerjee:
> Hi,
> I came across the tcpreplay tool and it looks like a nice tool for
> testing the network stacks. It can be used to capture network traffic
> and then play it back, this will help with testing the network packets
> from different network stacks.
Sounds like an interesting tool.
> My proposal is to add the tcpreply as a host-side tool in rtems-tools
> and use it with the network interface where the network application is
> running. The only issue that I see with the whole idea is that the
> tcpreplay is GPLv3 licensed. Will that be compatible for rtems-tools?
> The github repository says that it's compatible with UNIX and Windows
> with cygwin.
The more difficult problem could be the missing Mac and FreeBSD support.
What would be the advantage of having tcpreply in rtems-tools? Do you
want to use it for automated tests?
Best regards
Christian
> Source repository:https://github.com/appneta/tcpreplay
> <https://github.com/appneta/tcpreplay>
> Thoughts and suggestions are much appreciated.
> Best regards,
> Vijay
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
