[PATCH] riscv/start: Startup sequence update.
    Somesh Deshmukh
    someshdeshmukh07 at gmail.com
    Wed Apr 28 13:55:37 UTC 2021
- The current startup sequence performs the call to the bsp_fdt_copy() and then
  performs memset to the BSS region. In bsp_fdt_copy(), RTEMS allocates
  memory for bsp_fdt_blob into BSS region which is yet to initialize. With
  current startup sequence, the bsp_fdt_blob is getting erased after memset.
  The proposed fix performs the BSS region memset operation and then performs a
  call to the bsp_fdt_copy().
 bsps/riscv/shared/start/start.S | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
index 04a62a26ce..277760a388 100644
--- a/bsps/riscv/shared/start/start.S
+++ b/bsps/riscv/shared/start/start.S
@@ -74,17 +74,17 @@ SYM(_start):
 	LADDR	sp, _ISR_Stack_area_end
 #endif
+/* Clear .bss */
+LADDR	a0, bsp_section_bss_begin
+li	a1, 0
+LADDR	a2, bsp_section_bss_size
+call	memset
 #ifdef BSP_START_COPY_FDT_FROM_U_BOOT
 	mv	a0, a1
 	call	bsp_fdt_copy
 #endif
-	/* Clear .bss */
-	LADDR	a0, bsp_section_bss_begin
-	li	a1, 0
-	LADDR	a2, bsp_section_bss_size
-	call	memset
 #ifdef RTEMS_SMP
 	/* Give go to secondary processors */
 	LADDR	t0, .Lsecondary_processor_go
2.25.1
