Issues with rtems_waf on Windows 10 with gccdeps module
Robin Müller robin.mueller.m at gmail.com
Thu Apr 29 09:14:38 UTC 2021
I replaced the file in rtems_waf manually but it still throws the same
error:
[1/2] Compiling build/conf_check_995d7bdd1834199278843e9a51c37759/test.c
['C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe',
'-mcpu=cypress',
'-IC:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/sparc-rtems6/erc32/lib/include',
'-MMD', '../test.c', '-c',
'-oC:/Users/Robin/Documents/RTEMS/quickstart/build/conf_check_995d7bdd1834199278843e9a51c37759/testbuild/test.c.1.o']
from C:/Users/Robin/Documents/RTEMS/quickstart: Test does not build:
Traceback (most recent call last):
  File
"C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Configure.py",
line 335, in run_build
    bld.compile()
  File
"C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Build.py",
line 176, in compile
    raise Errors.BuildError(self.producer.error)
waflib.Errors.BuildError: Build failed
  File
"C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Task.py",
line 190, in process
    self.post_run()
  File "C:/Users/Robin/Documents/RTEMS/quickstart/rtems_waf/gccdeps.py",
line 140, in post_run
    raise ValueError('could not find %r for %r' % (path, self))
ValueError: could not find ['C', ':', 'Users', 'Robin', 'Documents',
'RTEMS', 'rtems-tools', 'rtems', '6', 'sparc-rtems6', 'erc32', 'lib',
'include', 'rtems.h'] for
{task 2179590063376: c test.c -> test.c.1.o}
no
from C:/Users/Robin/Documents/RTEMS/quickstart: The configuration failed
Kind Regards
Robin
On Wed, 28 Apr 2021 at 22:35, Chris Johns <chrisj at rtems.org> wrote:
> On 28/4/21 7:59 pm, Robin Müller wrote:
> > I think the following commit in rtems_waf breaks the waf build on
> Windows 10:
> > commit 096372fc4504730e50b51b952ce47ca603b35f01
> > Author: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> > Date:   Thu Oct 10 17:43:11 2019 +1100
> >     Use gccdeps for dependency scanning.
> > I get the error that RTEMS is not able to find the rtems.h file in a
> certain
> > directory when building the simple quick start application. The error
> does not
> > occur on commits before that. I tried to run waf both in the WIndows CMD
> and in
> > MinGW64, it is problematic for both.
> Could you please update your local version with ...
> https://gitlab.com/ita1024/waf/-/blob/master/waflib/extras/gccdeps.py
> ... and report back how that goes?
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210429/3a05db66/attachment.html>
