Issues with rtems_waf on Windows 10 with gccdeps module
    Gedare Bloom
    gedare at rtems.org
    Thu Apr 29 15:59:10 UTC 2021
On Thu, Apr 29, 2021 at 3:14 AM Robin Müller <robin.mueller.m at gmail.com> wrote:
> I replaced the file in rtems_waf manually but it still throws the same error:
> [1/2] Compiling build/conf_check_995d7bdd1834199278843e9a51c37759/test.c
> ['C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe', '-mcpu=cypress', '-IC:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/sparc-rtems6/erc32/lib/include', '-MMD', '../test.c', '-c', '-oC:/Users/Robin/Documents/RTEMS/quickstart/build/conf_check_995d7bdd1834199278843e9a51c37759/testbuild/test.c.1.o']
> from C:/Users/Robin/Documents/RTEMS/quickstart: Test does not build: Traceback (most recent call last):
>   File "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Configure.py", line 335, in run_build
>     bld.compile()
>   File "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Build.py", line 176, in compile
>     raise Errors.BuildError(self.producer.error)
> waflib.Errors.BuildError: Build failed
>   File "C:/Users/Robin/Documents/RTEMS/quickstart/waf3-2.0.22-1241519b19b496207abef1f72bbf61c2/waflib/Task.py", line 190, in process
>     self.post_run()
>   File "C:/Users/Robin/Documents/RTEMS/quickstart/rtems_waf/gccdeps.py", line 140, in post_run
>     raise ValueError('could not find %r for %r' % (path, self))
> ValueError: could not find ['C', ':', 'Users', 'Robin', 'Documents', 'RTEMS', 'rtems-tools', 'rtems', '6', 'sparc-rtems6', 'erc32', 'lib', 'include', 'rtems.h'] for
> {task 2179590063376: c test.c -> test.c.1.o}
It's looking for rtems.h in your rtems-tools directory and not in your
prefix. how did you configure waf?
> no
> from C:/Users/Robin/Documents/RTEMS/quickstart: The configuration failed
> Kind Regards
> Robin
> On Wed, 28 Apr 2021 at 22:35, Chris Johns <chrisj at rtems.org> wrote:
>> On 28/4/21 7:59 pm, Robin Müller wrote:
>> > I think the following commit in rtems_waf breaks the waf build on Windows 10:
>> > commit 096372fc4504730e50b51b952ce47ca603b35f01
>> > Author: Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
>> > Date:   Thu Oct 10 17:43:11 2019 +1100
>> >     Use gccdeps for dependency scanning.
>> > I get the error that RTEMS is not able to find the rtems.h file in a certain
>> > directory when building the simple quick start application. The error does not
>> > occur on commits before that. I tried to run waf both in the WIndows CMD and in
>> > MinGW64, it is problematic for both.
>> Could you please update your local version with ...
>> https://gitlab.com/ita1024/waf/-/blob/master/waflib/extras/gccdeps.py
>> ... and report back how that goes?
>> Thanks
>> Chris
> devel mailing list
> devel at rtems.org
